While speaking length splices can be totally acceptable on all but the finest pianos, in unisons that are wound bi-chords or wound tri-chords, speaking length splices can present serious hurdles to string leveling and the tunabilty of unisons.
Sent: 02-03-2026 13:35
Subject: Removing coil from base string
I concur with Paul. Speaking length splices, with a bit of the copper trimmed, sound surprisingly good. In my experience they usually sound completely normal.
John Pope
Lexington, KY
Sent: 02-02-2026 18:23
Mary,
If we're talking about Bb1 (in the bichord section) and it broke at the agraffe, that's an indicator that the piano has fatigue problems and you can expect more strings to break. This type usually breaks under heavy impact.
Hopefully when you get there you'll find that it broke at the tuning pin and youll have wire to work with to splice. If not...you've got what you need to do a SL splice. Watch for a splice tail such that it does not touch the other wire.
If though we're talking about Bb0 in actuality, that's a miserable place to make a splice and will require all the skill you have to make it work. Kudos to you if you're successful!
Sent: 02-02-2026 10:08
I didn't see the replies when I replied. You got some good advice!
Maggie Jusiel, RPT
Athens, WV
(304)952-8615
mags@timandmaggie.net
Sent: 02-02-2026 10:07
The copper is softer than the steel. Wire cutters can easily cut it with minimal pressure, and you just hold back to not cut the steel wire. HOWEVER, it can more easily buzz after it has been peeled back. Gently, very gently, use pliers to compress the cooper while gently adding a twist in the direction of the winding. If you push too hard, you'll know it because it will flatten, and you can peel off a wee bit more to try again. If you have ever done electrical work, cutting it is similar to stripping electrical wire, but in this case, the cutters will cause a break in the copper that can be the point the unwinding ends. I hope that makes sense. Maybe I should make a video. LOL
Maggie Jusiel, RPT
Athens, WV
(304)952-8615
