Luke,
For whatever reason I "assumed" they were plastic. I know of at least one 1959 L with ivory on it, and it was my understanding that it was a gradual shift over to plastic anyway.
Acrilikey will work. FYI, I hate the stuff because it gives me a headache from the fumes. You do need to create a "dam" underneath to support the repair. Like any cosmetic skill, it will require you to practice a bit and experiment. With a good respirator and persistence you can make them look reasonably good.
Sent: 03-15-2026 12:39
Subject: Repairing Ivory Keytops with No Front Lip
Link for manufacturer of AcryliKey:
https://www.wagner-technical.com/instructions.htm#:~:text=AcryliKey%20II%20is%20an%20ivory,the%20shop%20environment%20in%20mind.
David Skolnik [RPT]
Hastings-on-Hudson NY
(917) 589-2625
Sent: 03-15-2026 12:26
According to Kehl & Kirkland (Official Guide to Steinway Pianos - Hal Leonard), Steinway sent letter to dealers on 9/24/56, notifying them of the discontinuance of ivory keytops. It seems reasonable that the decision was purely economic, as I doubt there was any environmental pressure at the time.
Parker Leigh's observation comparing dental epoxy with AcryliKey might be valid, although I'm not sure 'softness' is the actual limiter. The extreme, in this instance, is that the material is not being used as a filler but an unsupported reconstruction.
I assume the acquisition of suitable replacement pieces is fraught... certainly in an on-line forum.
One possible approach might be to make a thin saw cutout and glue a 'dam' insert to support the plastic material. Once cured the 'dam' can be carefully ground/sanded away. Alternatively, a thin, rigid, CLEAR, acrylic piece could be inserted in an undercut and then built upon. This link is for material 0.01" (0.25mm) thick.
https://www.eplastics.com/ACRYCLR0-010IM24X48?inv=1&customer_id=813-364-8639&gad_source=1&gad_campaignid=20303024594&gclid=Cj0KCQjwsdnNBhC4ARIsAA_3hei11PuewV6IdBrCKMhUhFeNDd3VJfDr3RIc55rkADg1ofycDSAlpdUaAi3yEALw_wcB
David Skolnik [RPT]
(917) 589-2625
Sent: 03-15-2026 11:36
I would recommend dental epoxy instead. Acriylkey is too soft. Tint the epoxy as needed.
