Thank you, Chris.
Sent: 04-02-2023 21:34
Subject: Samick Hammers and Touchweight
I'll chime in,
Since I have been using inertia to make adjustments to a grand piano action, here is a different perspective, as there have been some interesting revelations.
- 1) Only one facet of inertia is only ever brought up, its level of intensity. But its note to note values for smoothness are completely ignored.
- 2) There's an ongoing assumption that I keep reading which is – If Strike weight is smooth, Friction is smooth, Front weight is smooth, then inertia must be smooth. I find this to be false of which there are several factors for this, but it turns out that front weight as a measurement exacerbates inertia problems rather than fixes them. Mainly because you reduce a leads effectiveness by sliding it back on a key.
Using a note in the middle of the keyboard for testing inertia also makes an assumption regarding the Inertia Range (average from Note #1-#88= 73g through 63g, a 10g of inertia force variance from bass to treble ). Instead of a middle key, I opted for using notes #2,#3 (which are the worse-case scenario 'normal keys') to do a load test to determine the proper amount of lead needed. Then I load test #86,#87. This way the inertia level is known and can be changed if needed, plus smoothness can be reliably addressed. Inertia smoothness can only be corrected when inertia is charted after results from the load test measurement. This also bypasses the need to use Action Ratio and Balance Weight as indicators.
Wippen assist springs would only complicate and make inertia smoothness a headache. I'm pretty sure those were designed with inertia level only in mind. My preference is to make things simple.
Basically this:
- 1) I use a standard one size fits all Strike weight curve.
- 2) Fix all friction
- 3) Use an inertia measurement to properly lead keys to control inertia level and smoothness.
I find this 3 step process fixes every action, stream lines the measurements, and provides super nice results.
"Where Tone is Key"
Sent: 04-02-2023 07:57
Thank you for your quick and helpful response, David.
Which of the Ronson products did you lean toward? I have used the Wieckerts on three piano thus far, and intend to install some of the Baconfelts in a couple of instruments this year.
Sent: 04-02-2023 05:00
Hi Floyd,
<o:p></o:p>Samick balanced their actions to a normal down weight with the support springs attached and no particular attention paid to how strong they were. We've seen many examples of a Samicks with a normal BW and no lead in the keys except for a heavy lead near the back check. Not ideal. <o:p></o:p>
For Front Weight ceiling (not always my choice), a medium inertial playing quality will be achieved with low Balance Weights of 33-37g range without support springs. You get that by adjusting hammer weight and/or action ratio. Best practice is to mock up notes in the center of the piano and see what StrikeWt/FrontWt/BalanceWt levels will make for a workable setup. I personally like to mock up at C4. A key indicator of inertia quality is the sum of BW + FW (without the support springs hooked up). C4 FW ceiling is 30g so that target for a medium inertia quality is 63g-67g. <o:p></o:p>
If you want to use the support springs the classic/conservative application emulates Hamburg Steinway production in the 1920s. They used support springs on 88 notes with enough tension to support the weight of the wippen. This means the springs on all 88 notes are working approximately 9g off the BW. Balance the action with springs unattached to a BW that is 9 grams higher than your final BW with springs hooked up. <o:p></o:p>
You can rough out the support spring tension with the stack on the bench and hammers flipped up. Adjust the support spring tension so the wippens hang level. Then fine the balance weight in the finished action after the keys are weighted. <o:p></o:p>
If you don't have 88 support springs it's best to taper the spring tension down to the break to avoid big changes front weight and the resulting in keystick inertia at that transition.<o:p></o:p>
I sold Samick pianos for many years and always removed the springs and replaced the new hammers with lighter sets from Ronsen and releaded the keys normally as a matter of course. This solved the inertia issues. <o:p></o:p>
David Stanwood RPT
Stanwood Piano Innovations Inc.
West Tisbury MA
(508) 693-1583
