  • 1.  Search terms in Journal index - modifying damper trapwork
    Posted 06-01-2026 17:26
    Hi gang,
    I'm trying to find an article that I'm pretty sure appeared in the Journal in the past 10 years about modifying old Steinway damper trapwork systems to the newer sort, with a  trapped pitman that goes through a large hole in the keybed and thus eliminates the pitman squeaking in the bushing.  Any suggestions?  I've tried searching for various combinations of the words trapwork, damper, modify, pitman.  What am I missing here?
    Zeno
    Zeno Wood
    Brooklyn, NY
  • 2.  RE: Search terms in Journal index - modifying damper trapwork
    Posted 06-01-2026 20:26
    "David Hughes" maybe?
  • 3.  RE: Search terms in Journal index - modifying damper trapwork
    Posted 06-01-2026 20:55
    That's a good idea, and I was also hipped to a great article he wrote in the June 2017 issue.
    But I realize I wasn't very specific about what I'm specifically looking for.  I want to drill a larger hole in the key bed for the pitman!
    Zeno
    Zeno Wood
    Brooklyn, NY
  • 4.  RE: Search terms in Journal index - modifying damper trapwork
    Posted 06-01-2026 22:00
    Modernizing the Damper Lift Dowel by Doug Wood, September 2000 (article mentioned in a different article in May 2023)
    Daniel DeBiasio
    Technical Education & Support
    ddebiasio@steinway.com
    718-267-3229
    Steinway & Sons
  • 5.  RE: Search terms in Journal index - modifying damper trapwork
    Posted 06-02-2026 07:39
    This will be a mod I'll be needing to do on an old Model A in the near future. I recall David emphasizing to me (the last time I did it) to make sure I bush both pin holes with cloth (tray and lever) to avoid inevitable squeaks.
  • 6.  RE: Search terms in Journal index - modifying damper trapwork
    Posted 06-03-2026 12:27
    I don’t think the extra step to add pins and bushings is worth the effort or risk of future squeaks.
    The modified pitman without pins works quite well, and the pedal action is vastly smoother than the original bushed pitman, which seems to be the cause of squeaks and slow damper return.
    NYC
  • 7.  RE: Search terms in Journal index - modifying damper trapwork
    Posted 06-04-2026 09:53
    This is the outline I follow to do this job:
    Steinway grand sustain pitman update
    1        Put drop cloth under piano
    2        Remove action
    3        Remove leather from damper tray (screwdriver)
    4        Hold sustain tray down with wedges
    5        Arrange tools around piano for access while under
    6        Remove damper lever stop hook completely
    7        Remove pedal lever with spring and old pitman, pull pin
    8        Attach 1" hole guide over old pitman hole (not spring hole)
    (The una corda lever block may need to be removed)
    9        Wear facemask
    10      Drill out pitman hole, remove hole guide part way through
    11      Use 1" drill to dimple the center of the damper tray
    12      Drill ¾" hole in lever, centered on old position, leather removed first
    13      Drill ¾" hole in damper tray though the keybed, leather removed first
    14      Clean up holes with sandpaper
    15      Clean drop cloth, replace under piano
    16      Remove wedges from damper tray
    17      Adjust pedal rod to middle, if adjustable
    18      Polish lever pin (looks like a hinge pin)
    19      Reattach lever with spring, using dummy pin (1/6" rod)
    20      Select correct size new pitman
    21      Reinstall damper lever stoop hook
    22      Make final pedal adjustments and reinstall action
    23      Clean up                 Total time about 1 ½ hours
    On occasion I will also swap out the spring with a weaker one if the pedal is still too hard to push down.
    Bruce
    Bruce Dornfeld, RPT
    Dornfeld Piano Tuning
    Phone: (847) 498-0379
    Cell: (847) 997-4266 (text)
    bdornfeld@earthlink.net
    www.Dpianotuning.com
    2134 Walters Ave
    Northbrook, IL 60062-4528
    Making Pianos Sound Beautiful Since 1979
  • 8.  RE: Search terms in Journal index - modifying damper trapwork
    Posted 06-02-2026 12:36
    If you Mario Igrec’s book, there’s some info, don’t recall if there are stepped instructions though.
    You can message me privately if you want, I have some experience with that conversion.
    Joe
  • 9.  RE: Search terms in Journal index - modifying damper trapwork
    Posted 06-02-2026 14:19
    I just drill a hole in the tray. Make a hardwood dowel that won't touch the sides of the hole in the keybed. Put a pin on each side of the dowel. Add a balance rail felt punching. Boom done.
    chrisppff@gmail.com
    Youtube@chernobieffpiano
