Sent: 12-23-2025 15:16
Subject: snugging up loose harpsichord tuning pins
Don-
Perhaps you could return to Google AI and ask "Does any if this matter when shimming a loose harpsichord tuning pin, and if so, where can I get a grant?"
Sent: 12-23-2025 14:35
Alan,
Please post your thoughts on this subject when you are finished with your project. I have never heard of using archival paper as well so I'm sure many of us will be interested in hearing the results.
I asked the question on Google about the difference between using buffered and unbuffered paper as it related to metal. Below is the AI response. Interesting!
Thanks, Don
For metals, the key difference is that
buffered rag paper (alkaline) can sometimes cause chemical reactions or corrosion (tarnishing/bleaching) with sensitive metals like silver and copper, especially if damp; while unbuffered rag paper (neutral pH) is safer and generally recommended for most metals and protein-based artifacts, though some buffered papers are soft enough for gentle use if kept dry. Always use soft, neutral (unbuffered) tissue for metals if unsure, or if they have special finishes/coatings, as buffering agents (like calcium carbonate) can be reactive with some metal compounds.
Buffered Paper (Alkaline)
- pH: 7.5 - 9 (alkaline, due to calcium carbonate).
- Best For: Cellulose-based items (cotton, paper, linen), ceramics, some photos.
- With Metals: Avoid or use with extreme caution. The alkalinity can react with silver, copper, and other metals, potentially causing tarnish, bleaching, or corrosion, especially in humid conditions.
Unbuffered Paper (Neutral)
- pH: ~7.0 (neutral, no added buffer).
- Best For: Animal-based items (silk, wool, leather), protein-based photos, and metals.
- With Metals: Generally safe because it lacks reactive alkaline agents; it won't neutralize naturally acidic metal surfaces as aggressively as buffered paper.
Key Consideration for Metals
- Silver & Copper: Highly prone to reaction with alkaline buffers.
- Dampness: Moisture exacerbates chemical reactions; dry storage is crucial.
- General Rule: When in doubt about a metal object, use soft, unbuffered, neutral pH tissue to prevent chemical harm. Some buffered tissues are soft enough for gentle use on metals if kept very dry, but unbuffered is the safer archival bet.
[Don] [McKechnie,] [RPT]
[Piano Technician]
[dmckech@ithaca.edu]
[Home 607.277.7112]
Sent: 12-21-2025 23:56
Dave,
I am finally getting around to trying to acquire the shimming material you referenced.
I have to choose between "buffered" and "unbuffered."
What do you recommend?
Sent: 11-06-2025 15:58
FWIW, I restrung several instruments under Bill Dowd's supervision some time back. He insisted on using shims of archival, acid free, rag paper. We put it in the holes exactly as Fred suggests above. Never had a problem with it. Glue will seep into the wood around the pin and stain it, I would think.
--Dave
New Orleans
504-263-2923
dave@nolapianoworks.com
Sent: 11-06-2025 15:35
Hadn't heard about using veneer for this before. Thanks Jim!
Sent: 11-06-2025 12:43
Make a shim out of thin veneer that is wider at top than the bottom. Top should go 1/2 diameter at top, and about 1/2 that at the bottom. Place shim where pin pushes on it.
