"Too loud" needs to be better defined. Yes, a rug under the piano can help a lot because it gets rid of one reflective surface. And works in most locations most of the time when dealing with a hard floor. And foam inserts inside and underneath the piano can work if the piano itself is perhaps too harsh in any environment. But is it the piano, or the room? If the piano is sitting in a room with walls that are parallel, and/or the floor and ceiling are parallel, and/or all the surfaces are hard, the reflections off these parallel surfaces will create standing waves that may actually amplify the sound of the piano. This can happen in both rooms that are too large and rooms that are too small for the piano that is in them. Curtains can help. Rugs and furniture can help. Even moving the piano around the room to a location where the reflected soundwaves off walls and ceilings are not as strong can help.
The other thing to consider is, it is too loud for the pianist or too loud for other people in the room? Player systems have a history of being too loud, especially when you want the piano as background music during a party that is happening in, or near, the same room that houses the piano.
I have one customer with a 9' Hamburg S&S. It is sitting at the far end of a rather large room, with carpeting and furniture. But the problem is that it simply overpowers the room. It is too much piano for the room regardless. A 7' would be perfect. On the other hand, when I sit in the middle of the room, listening to the owner play after tuning, it sounds quite perfect. In other words, this piano is too large, and therefore too loud, for the pianist, in that room, in that location. I am of the opinion that if there was room for the piano to be rotated a bit everything would work better. But the room won't allow for that.
