Fuhgetabout it. Buy a new spiderdolly/truck that will fit a D. New production parts are very likely to differ from the old parts requiring some tricky woodworking with routers, forstner bits etc You might want to check the condition of the interlocking butterfly plates where the leg is attached to the piano. All of the moving around on the casters/wheels could have compromised the screws/screw holes and cracked the plates. Make sure you have plenty of jacks, metal saw horses, jack stands to support the weight of this beast. btw I have never seen rubber wheels on grand pianos-only on studios and full uprights.
Sent: 12-03-2023 00:02
Subject: Steinway D replacement casters
I would be surprised if Schaff does not have what you need. They have casters with different stem diameters and both round and square sockets. Know the measurements of what you need when you speak with them.
