You're not hijacking my thread. You're staying on subject and providing interesting and useful information. I'm grateful that my post garnered such interest. (BTW, you hinted that your previous post had pictures but... um... where are they?) Now, if your posts somehow changed the topic to something else, that might possibly be hijacking but it would really be an indication of someone not knowing how list servers and forums actually work.
Sent: 03-16-2025 17:06
Subject: String splicing question
Allan - Hope I'm not hijacking Geoff's thread. He may be interested in these pictures. One is a few knots where I made the loop on the new string segment large enough to go over the winding. You can tell which one I didn't bend inward far enough because it caught the winding. Boy was I annoyed with myself for that one. The other picture is of your knot and one of mine, which I would have called a standard knot. They are different in that my tails are against each other on the inside while yours are going through the outer part of the loops. I'm definitely going to be trying that one. I already like it better. ;-)
Tim sez: Le plaisir sera le notre. Peut être à Des Moines bien que nous avons toujours voulu venir au Canada.
Maggie Jusiel, RPT
Athens, WV
(304)952-8615
mags@timandmaggie.net
Sent: 03-16-2025 09:26
Maggie,
I'm glad you like my knot! It's actually a traditional knot, just threaded differently. I still need to determine the right proportions between the wire thickness, the loop diameter, and the tail length.
The challenge with larger winding is exactly why I started using this method-it keeps things more compact and secure. I'd love to see your pictures, even if they're just the end results!
...and... Bonjour Tim, au plaisir de se rencontrer un jour....au Canada ...��
Sent: 3/15/2025 10:43:00 PM
Subject: RE: String splicing question
Hi Geoff et al!
Sorry I didn't see this sooner. Glad you found my video useful! Yes, the hybrid knot is in there, but I just fell in love with Allan Sutton's knot. I expect I'll be using that in the future! I was going to share that I have done a traditional knot with a small amount of wire left near a winding by making the loop on the new piece of wire large enough to pass over the coil. This can work quite well when the coil isn't too think. I have pictures, but only of the end results. I expected I'd be trying this eventually on a thick coil, but I'm thinking Allan's knot would be better because it would avoid the extra large loop.
Daniel - Those are fantastic photos!
Allan - When I started playing your video, Tim (hubby) was in the room and started translating for me automatically. Haha! ;-)
Maggie
Maggie Jusiel, RPT
Athens, WV
(304)952-8615
Sent: 03-15-2025 15:08
Daniel --
When I first saw your original post I just glanced at it as a description of how I already splice wires. But after reading Ron Koval's response I looked at it more closely. I agree, the use of the dummy wire for making the loop is a great idea that I had never heard of before. My only addition to the instructions you have provided would be to select the next thicker gauge wire for the splice wire. I was taught this as a way to reduce the possibility of the splice wire stretching and causing some minor instability after bringing the wire back up to tension. You are correct that your response did not address the question I had posted but it was, nevertheless, a valuable addition on the subject of wire splicing. Thanks --
Sent: 03-14-2025 09:48
Geoff,
I read your original post again and realized that the tutorial I posted was not what you were asking for.
I think you might be thinking of the January 2019 issue of the Piano Technician's Journal.
Also, Maggie Jusiel has an excellent video on YouTube about this topic called "Three Piano Wire Knots"
Daniel DeBiasio
Technical Education & Support
ddebiasio@steinway.com
718-267-3229
Steinway & Sons
