I feel pretty confident in my ability to recognize a problem that needs a solution and finding the best solution.
The piano was purchased by a concert venue that I work for from a dealer who had the work done. So I'm the one taking care of the piano. It was untunable, snapping, unmovable pins. I was actually concerned that I might shear one off. There was/is no concern that these pins will ever be too loose. I originally posted the problem here for discussion to see if others had encountered a similar problem to see if there was a better idea.
I suspected that the pins used were too oversized (they went up two sizes) and might be too long as well (they were). I verified that with the rebuilder. The least of my concerns was whether I had their blessing for the solution I undertook. I would have never sent the piano out that way.
The "new variable" of pin manipulation I consider to be a non issue (as you may note from my post).
I guess the short answer is I don't operate out of fear of what ifs. I determine the problem, determine the best solution, and move forward. There was no other option. BTW I discussed the problem with the dealer and the venue and the dealer took responsibility and paid me for the remedy, This is now 2-3 years ago and the piano is much better and holding just fine I will also mention that it wasn't the only thing that needed attention but those owns were more conventional.
The solution I undertook btw is not a crapshoot, it's perfectly controllable if you are paying attention.
www.davidlovepianos.comdavidlovepianos@comcast.net415 407 8320
Sent: 07-29-2025 19:22
Subject: Tuning Pin Torque and Heat
You mentioned the D was rebuilt with too tight tuning pins. Before proceeding with your torque reduction procedure did you discuss this condition with the owner so they could involve the re-stringing person to, hopefully, concur with your solution? Another variable (i.e. tuning pin manipulation) has been introduced into the system and not necessarily documented. Should another technician in the future feel the tuning pins are too loose, the re-stringer could be on the hook and expected to correct the situation. I would probably do the same thing for a couple of too tight pins but would be hesitant to do the whole piano.
John Ginter
La Grange TX
(832) 722-3033
Sent: 07-28-2025 02:15
Can't comment on whether the important factor is heat or just movement of pin in the block, though I'm somewhat inclined to the latter. I have had two situations in the last year or two where the pins were simply too tight and fine tuning was not possible. One was a rebuilt Steinway D in which oversize pins were used plus they went from 2 3/8" to 2 1/2" pins. The piano was a bitch to tune (can I say that?). I posted this on the list. What I ended up doing was rotating each pin about 8 - 10 times back and forth about 1/4 turn each way after backing the pin off slightly to take the tension off first. I did this quite slowly, did not let the pins cool between turns. The method worked very effectively to reduce the torque and rendered the piano very tunable. After doing several pins I got to where I could feel that the torque would end up where it wanted and when to stop. I had a similar experience with a B that was also too tight ( for different reasons). Same procedure. FWIW I did only the upper half of the bass strings as I did not want to break anything. I have also done this on individual strings that are snappy and it can work effectively there.
Again, I can't report as to whether it was the heat or the turning--or both--but it was effective and no residual problems. Good workout too!
