I tune uprights right handed for two reasons. One is that I prefer to tune uprights from the 1:00-1:30 position which means that the pin will flex the pitch very slightly to the flat side and thus you can tune more directly to the target pitch. Tuning left handed you will raise above the pitch and then settle it back down. That technique was based, I believe, on the idea of not stressing the front of the tuning pin hole. I don't think it's an issue. Also, I find that much of my tuning control comes from the ability to feel the pin move in the block and being right handed I just am able to feel that very tiny incremental move much better with my right hand and control those small movements. But to each their own.
Sent: 05-18-2023 20:57
Subject: Vertical Piano Tuning Ergonomics
While I do advocate tuning uprights lefty, I only mention levering of an elbow or forearm as a potential added benefit under certain situations. Usually, when pitch raising smaller uprights as it can take some of the stress of of shoulders. I don't recall Braid White mentioning elbows. If I were tuning uprights righty, I imagine that I would have the tuning lever around 12:00 o'clock and using my elbow on the top of the piano when possible. But, I don't do uprights righty with the exception of very low bass notes under certain situations. (Baldwin Hamilton or upright left side up against a wall)
Tremaine Parsons RPT
Georgetown CA
(530) 333-9299
Sent: 05-18-2023 15:27
I had Reblitz's book in my hand early in my development as a tuner, and as I review what he says, it seems clear that I pretty much embraced his recommendations -- use of the dominant hand rather than an ambidextrous approach, a hammer position just off of vertical, and a commitment to resting the elbow somewhere to heighten control.
In the responses above, Larry advocates a left-handed approach with no resting of the elbow.
Tremaine suggests a between-10:00-and-noon position for left-handed tuning, together with levering off of the fallboard or the left side of the case, where possible. He also cites Braid White who says some of the same, and who advocates standing to tune.
When I stand to tune the center section of a U3 with a standard lever, there is no obvious place to immobilize the elbow, so I end up in the situation Reblitz describes with the words "With your elbow hanging in mid-air, your shoulder is also a pivot point, decreasing control."
It may well be that a good measure of the frustration I feel when I try to tackle this task is owing to an insufficient ongoing commitment to maintain muscular strength in my shoulders. Even without the load of free-elbow tuning, I've run into grief with shoulder pain, though things are not uncomfortable in recent days.
I would appreciate what further insight this community has to offer.
Sent: 05-17-2023 12:54
The following applies to traditional Tuning Levers:
When I started learning, the Braid White book "Piano Tuning and Allied Arts" was my bible. He recommended tuning uprights with lever in left hand between 10:00am and noon with some explanations as to why. The 1st printing is in the public domain for download. As we are more often raising pitch we are pulling upwards in the same direction that we are pulling the string through the bearing points. I tune grands with the lever in my right hand positions roughly between 1:00 and 3:00. Again, if raising pitch, pulling the string in the same direction passing through the bearing points.
Most importantly, I have been splitting the load on my wrists and shoulders over nearly fifty years. Granted, I tune far more uprights than grands but I know it has made a difference.
I mentored a friend who learned in the later 70's to start tuning uprights lefty and he has thanked me many times over the years for this.
Finally, tuning uprights lefty allows one to reduce additional load by levering with your elbow on the fallboard of spinits and consoles. Also levering off the left side of the case with your forearm. I encourage all people starting to try and tune uprights lefty.
Georgetown CA
(530) 333-9299
