Good Day everyone!
I have a customer with a late 90's Mason Hamlin Vertical with a sostenuto. I've regulated sostenutos many times on grands, but this is the first for me on a vertical. It's a Renner action, and it uses a grand-style sostenuto rod, which should catch a felted tab on the damper, right behind where the damper wire leaves the damper lever, directly above the damper spring.
It seems like a very delicate system, and there is not much wiggle room (literally, as the sostenuto tabs are rigid!).
Does anyone have any references on the best operating procedure for regulating these systems? Or any tips and tricks that might help?
Thanks in advance!
Tom Dowell
Hulbert Piano
tom@hulbertpiano.com262-221-0792
