I worked on a Wurlitzer spinet with key end forks and wire stickers earlier this week. Amazingly it had no visible rust on the coils, steel wire, tuning pins something rare in our humid climate. A few slow hammers but most of the piano was not wild . I measured A4 on my SAT III and could not get the lights to stop until the display read 198 cents flat on the middle string. I tried this several times and got the same result. I put the mute between the middle and left string measured the right which was 100 cents flat ; put wedge mute between middle and right and the left string was 100 cents flat . with the mutes out the unison was not wild so what is the reason the unison is fairly clean ? are the vibrations all blending together
