I also use the System Three wood putty, but Elmers and Albatron seem to be about the same.
Wood is preferred but there is a limit in resources for making and storing materials and tools.
Dean, I would like to get an assortment of plugs. For a small shop like the one here there is not much
time available for cutting plugs nor space in an already crowded shop of only a couple hundred feet
of usable space. There is a real limit to what can be done. Your arrangement allows for much easier
access to resources for this type of thing.
Dave
Dave Conte, RPT
Piano Technician in Residence
The University of Tennessee
College of Music
Knoxville TN
(817) 307-5656
Owner: Rocky Top Piano
Sent: 10-22-2023 13:14
Subject: Wood filler alternatives
Hi Scott,
Since our shop makes keysets, we see lots of attempts at plugging lead holes. In my opinion there's nothing as well matched to keys as a similar or the same wood species plug with grain orientation to match. The same species is best, but spruce and pine are pretty much interchangeable.
During re-leading, you'll sometimes be drilling part of the plug and real wood will end up a much better job. It looks better and it doesn't degrade the key's strength and stiffness. And frankly, it's a faster job.
What doesn't work well is maple or birch plugs made from hardware store dowels. The grain is going the wrong way which means they will eventually separate from the keystick and maybe click or certainly cause weakness in the keystick.
Well matched plugs are also very fast to install. For making plugs, I have a shophand spend a half a day making them in bulk. We make plugs in every size and from many different species to match keyframes and keys.
We make our own key plugs from kiln-dried spruce, from scraps of keyblanks of course. But we have way more spruce key scrap than we can use. If anyone out there will pay for shipping, I'd be happy to send any PTG member a small box of kiln-dried clear keyset quality spurce for plugs. Plug cutters are readily available and easy to use on a drill press.
Hope that's helpful,
-Dean
Dean Reyburn, RPT
Reyburn Pianoworks
Reyburn CyberTuner
1-616-498-9854
dean@reyburn.com
www.reyburnpianoworks.com
www.cybertuner.com
www.reyburntools.com
Facebook: www.facebook.com/dean.reyburn
