I’m looking to regulate a G1 from 1969 with original action parts. Strings may have been replaced at some point and it’s possible the plate has been removed also. Pinblock looks original, and though I see evidence of bowing down in the middle, torque throughout is very good.
I found the hammer travel at 41.5 mm. The most I could lower without running into the rest cushion was 2 mm. I’d like to be able to get at least 44 or preferably 45 mm (though 46 is ideal.) Key travel is 10.2 mm at the least, and obviously this creates much too much aftertouch. Hammer bore seems good (equal to string height minus flange center.)
Even with the pinblock bowing, there’s ample space for drop screws. Back rail cloth height seems rather thick, though appears original. There’s room under the fall board to raise the key height a couple of mm, so lowering the back rail felt is possible to try for more hammer travel. I have not adjusted the glides though they are near enough to create a good regulation foundation.
Where might elsewhere I look to gain more hammer travel? Cut down rest felt? Plane down action feet rests (cleats?)
Obviously I’m hoping to get the piano feeling better and more responsive without causing a catastrophe in action ratio or touchweight.
Board and downbearing seem ok, tone is slightly weak, but ok I think for a 53 year old instrument.
Any input as to where to search for a good solution (or at least a decent compromise) highly appreciated!
NYC
