The GA1 (about 2001 to 2005) is actually worse than the GH1 but it was an interim model towards the GB1 that came in around 2005 which mostly fixed the scaling problems of the bottom 6 plain wires by changing to 5 bichord bass notes on the lowest plain wires. On the stock factory GA1, B3 plain wire note is only about 90 Lbs of tension per string. It gets progressively better up to E3 at about 124 Lbs tension per string. This is the main issue to stability (low tension blip). The GH1 has this problem as well, to a lesser degree, with really only the bottom 4 plain wire notes being too under tensioned. I have a number of GA1's in CA that are quite stable with the exception of this under tensioned area. Along with the low tensions there is also high inharmonicity so the 4:2 and the 6:3 octave tests will absolutely not agree for any of these 6 notes.
I have converted the 6 low tenor of GA1 plain wires to bichord bass notes on 3 occasions over the last 20 years and yes, it makes a huge difference!
It's a bit long, but you can watch and hear a before and after video at: http://goptools.com/360vids.htm (6 Note Low Tenor Plain Wire to Bichord conversion)
John Schienke at JDGrandt has the patterns and specs for anyone who would like to do this. The main problem is the first 2 years of getting the new bass strings to settle down. I also have a white paper regarding this so email me if you want that pdf and more info. So, one has to consider the client, their usage, player proficiency, client ears for octaves ... If the client can hear the tuning anomalies, is limited in budget to upgrade, then the conversion would be worth doing.
Also, one would be well advised to consider pointing out these anomalies to the customer in advance because, as in the first post, the client is calling back to try different Technicians due to not being satisfied when the problem is more than likely the be the scaling issue from the git go.
This is NOT a promotion for Pscale! Pscale has been around since 1990 and I don't care whether I sell the program or not.
Tremaine Parsons RPT
Georgetown CA
(530) 333-9299
