Blaine,
Success, absolutely, but the conversion requires special know-how. Purists will say that the original rocker system should have been left alone. But that is a conversation for another thread.
You say you worked on the piano. Just tuned, touched up regulation, voiced? In any case, is the owner complaining? I assume that the excessive DW of 65 - 70 g represents heavy weight (and excessive key leads) in all sections of the scale. This being the case, clearly something is wrong.
Rocker arm conversions require special attention, especially at the capstan top to wippen heel interface; not only the fore and aft location, but the z dimension as well (relates to depth of wip heel and height of capstan block pedestal and the magic line). Are you planning to dismantle the action to investigate further? Are you contemplating a fix? If so, the job would likely be extensive and expensive.
The key ratio (for vastly general purposes) should be ~0.50:1 (typically a bit shorter at 0.048:1) for traveling distance purposes (sometimes acceptably referred to by its inverse of 2:1, but technically that relates to mechanical advantage). But even these benchmark dimensions are subject to tweaking a bit in order to get the whole thing working with (more or less) acceptable and expected regulation specs.
The knuckle location is also a very significant parameter. The replaced Renner shank may be carrying a short-distance knuckle of only 15.5 mm from the center pin. This would contribute to a heavy touch.
Given a correct key ratio, a corrected capstan pedestal block height, a corrected knuckle location, the overall action ratio will fall in line to ~5:1, which is something of a standard. If desired, a more advanced and customized approach seeking a higher AR, would eventuate in a shallower touch (still with acceptable aftertouch), but that would require lighter hammers. Higher ratio actions with lighter hammers are snappier. Many vintage Steinways were built this way. Then there is the whole inertia thing, but we're not going there right now.
Anyway, following either the standard AR route or the higher ratio route, and finished out with appropriate hammer weights, rocker arm conversions can be reworked to an acceptable performance level. But it's a big job.
Good luck.
Nick Gravagne, RPT
Mechanical Engineering
Nick Gravagne Products
Strawberry, AZ 85544
gravagnegang@att.net 928-476-4143
Sent: 09-08-2022 06:07
Subject: 1866 Steinwayaction geometry
From the picture, it would appear the current key ratio doesn't come close to a 2:1 ratio, given the new location of the capstans. Also, the wippen heel/capstan location may not be ideal either. It looks as though the wippen heel needs to be extended and the capstan lowered. These are areas I would consider first.
Rick Butler RPT
The Butler School of Piano Technology
Bowie MD
240 396 7480
RickRickRickRickRick
