If you punch it out and find that it is intact you can always mix up some JB Weld and "glue" it back in place. You can use a caliper to make sure the height is the same as the others and also keep the alignment straight on the hooks by sighting down the line to make sure they will all engage the brackets in the same plane.
If it is broken you can make a new hook by getting piece of steel rod the same approximate diameter as the original. (A piece of a similar diameter nail can be used for your rough stock) Cut a length of rod long enough to make up the entire amount needed. Chuck your piece in either a drill press or a hand held electric drill and use a file to round over the ends so they won't catch the felt bushing of the hanger and also will go freely into the hole in the lift rod.
Heat the replacement piece so you can make a sharp bend just like the originals. Once it has cooled you have a replacement part. At this point you can JB Weld the replacement into place but it is best if you take a steel countersink and bevel the hole in the rod. This will give a little more surface area for the JB Weld to form a glue collar on both sides of the rod. Use the caliper to set the height as I described in the first paragraph. Let it set for 24 hours and then trim off the part that is protruding out of the rod. You can see evidence of trimming and grinding of the original hanger pins on the back side of your lift rod. Assemble and test. Good luck
Norman Cantrell
Sent: 2/17/2023 2:26:00 AM
Subject: RE: 1946 Lester - Treble/mid damper lift rod not raising bass damper lift rod
Okay, I'll give that a try tomorrow. I'm wondering what exactly the next steps would be after that. I could try to find a replacement the same size but I imagine it would be difficult fitting it in tightly as well.
Matt Hill
South Pasadena CA
(323) 358-1315
Sent: 02-17-2023 01:37
Subject: 1946 Lester - Treble/mid damper lift rod not raising bass damper lift rod
My suspicion then is that it is broken or cracked inside of the rod. I would try to remove it by punching it out from the other side.
Sent: 02-17-2023 01:30
That photo was a tight one. Here's the other side of the loose one.
Other side of Loose L
It jiggles in all directions but doesn't rotate.
Matt Hill
South Pasadena CA
(323) 358-1315
Sent: 02-17-2023 01:01
Is that other side the loose one or a tight one. (those are incredible photographs)
Does the loose one jiggle from side to side or rotate?
Sent: 02-17-2023 00:54
Thanks so much Steven for your help!
I'm not for sure if these are pressure fit or soldered. Here's a photo of the loose one.
Loose L-shaped stand off
Here's a photo of a non-loose one.
Normal L-shaped stand-off
Here's the other side where it goes through if that helps.
Other side of rod
Does anyone have any methods of tightening this?
Matt Hill
South Pasadena CA
(323) 358-1315
Sent: 02-17-2023 00:27
Others might have better ideas than me. Do they seem to be pressure fit into place or soldered? You might be able to tighten it by "peening" it with a round hammer or possibly a center punch. It's really important that all of the L shaped stand-offs are the same distance from the rod and in line with each other.
Hopefully others will have some more advice how best to get that piece tight again.
Sent: 02-17-2023 00:12
Wow, that was easy to remove the rod. That L shaped stand-off nearest to the junction is loose. What would be the best repair for this?
Matt Hill
South Pasadena CA
(323) 358-1315
Sent: 02-16-2023 23:55
The good thing about that unusual action is that the rods are easy to remove, there will be one of the L shaped stand-offs that is oriented in opposition to the others, if you unscrew the hinge the rods will come off the rail for inspection. If none are broken, test them with some pliers to see if they are loose in the rods.
Sent: 02-16-2023 23:47
Thanks. I just looked and the base of the L shaped stand-off nearest to the juncture is discolored and worn looking. The others aren't like this. It's still connected to the hinge and that's screwed in.
Here's a photo.
https://www.dropbox.com/s/4bkacnbzovfmmoq/Lester%20Hinge.jpeg?dl=0
Do you think this is causing the problem? Any ideas for a solution?
Matt Hill
South Pasadena CA
(323) 358-1315
