I'm perplexed.
Why is there no discussion regarding the merits of undertaking a restringing on a piano that has been subject to the described conditions?
And then there's Don's shimming advice. I feel like it was himself that challenged the physical dynamics of stress on pinblocks using hard tuningpin bushings. The direction of force on the block is toward the stretcher, being pivoted by the bushings in the pin field. In theory, the precise fitting to the flange is irrelevant. Don, did I miss something back then?
David Skolnik [RPT]
Hastings-on-Hudson NY
(917) 589-2625
Sent: 03-02-2026 20:37
Subject: 1977 Yamaha C3 Tuning Pin Bushings
Order replacements from Yamaha. Usually the Japanese ones are hard, and they come in different heights (9 - 11mm, maybe 1/2mm steps) .
You might also consider checking and shimming the pinblock at the flange if it needs it, that might make the end result more stable.
