Hi David,
Correct, the customer is not considering a full rebuild. Here is an amazon link to my saved photos, please let me know if you have any trouble opening the link. (
Decker Brother's photos) I believe the customer is interested in the visual, but he was also aware that new pins would change the visual somewhat. I'm open to working with the old pins. Most of the bass strings are still intact, but three of the 32 broke when I attempted to raise the pitch, which we expected (they broke while still around 100 cents flat). You make a good point about not testing an original pin block, which it is definitely original (these are really hard to remove, since the block is mortised into the frame). CA and original pins is still very much on the table.
Thank you for your thoughts!
Tim Foster
Sent: 10-25-2022 11:04
Subject: 2 inch tuning pins
It didn't occur to me that this might be an open face block, but the 2" pins then make sense. Also, I'm not sure how much more visual information you can accumulate than by having both the top AND the bottom of the block accessible.
Tim - have you removed bass strings yet? I think it's the general assumption that you are not considering a full rebuild; that you are, to the extent possible, planning to work with the existing structure and components.
Can you supply any photos? How important is maintaining visual consistency? If tuning pins are looking old and oxidized, putting new pins in the bass will certainly be different, even if blue (or black).
I think there might be a number of reasons for advocating re-use of the existing pins.
- Even if you had room to tap deeper, or add length, creating the additional torque at the bottom, it's less than ideal, since you end up allowing the introduction of additional torsion over the length of 'unsupported' pin.
- I took a moment to peruse my Pierce Atlas (the opportunity for which I thank you). If this is, in fact, a Decker Bros. (as opposed to a Decker & Sons), the last serial numbers are in 1895. If this is an original block, I would be very wary of testing its health by driving larger pins, even if properly supported.
I'd be inclined to lean (redundant, I know) towards using original pins with CA treatment.
I'm willing to be tarred for that comment.
Which reminds me: has anyone seen that movie yet? Kate Blanchett as a conductor?
David Skolnik [RPT]
Hastings-on-Hudson NY
(917) 589-2625
Sent: 10-25-2022 10:02
Drill a small hole thru the block and check thickness with a wire.
Sent: 10-25-2022 08:17
Jon, thank you for the info. Yes, it is an item face block. It's a very unusual design-- the holes are not drilled all the way through, the bottom of the block is smooth without holes so I need to investigate further how deep, etc. The top of the block is slightly tilted towards the back, and 88 agraffes. I'll be talking my time for sure.
Tim Foster
Sent: 10-25-2022 07:14
Maybe the reason the pins are loose is that they were not deep enough into the block. If the block has the thickness, I'd replace with 2 ⅜" or 2 ½" pins. At least 2 ½" on the single strings, reason being the wire is of a larger diameter and while maintaining the same coil height above the string frame there would be less pin in the block.
Ream the block accordingly. The only reason I can think of for a short pin is if they are installed in an exposed pin block.
Sent: 10-24-2022 08:53
You might need the longer pin in case there is an acute angle form the termination to the pin.
Sent: 10-24-2022 08:30
Tim,
I doubt you will find 2" TP's anywhere. Looks like 2 1/4" is the way to go. However you'd better check the depth of the holes first just to make sure you've got the space.
