Interestingly I am rescaling a 5' 8" Stieff grand that (on paper) wants this exact pattern around the treble strut. Goes from #15 to #14.5 on each side of the strut and then back to 15. This keeps tension much more consistent through there rather than straight #15 throughout.
The piano was restrung very badly years ago so I have no original data, but the way the hitch pin and bridge patterns are set up suggests that originally they may have done exactly this. I would be interested if anyone has access to an original Stieff Scale 37 to compare.
Sent: 02-01-2025 10:41
Subject: Baldwin string scale
Thank you, Tremaine. Indeed, it's not often that you see such changes in gauge.
Another thing that stands out on this grand piano is the small distances between the bridge pin rows near the transitions. Something new to me is the individual front terminations-some have a wider bearing surface than others.
Do you happen to know if this is because they were replaced and the original size was unavailable, or was this done with a specific purpose in mind?
Best regards,
Arnold Duin
Arnold Duin
Krommenie NH
31-75-6211529
Sent: 01-31-2025 09:49
Arnold, I measured an SF at a conference years ago because I wanted the scale for comparison with others. However, I likely used the plate markings for the gauge sizes. Below is what I have in my scale file which matches what is on your plate. This Baldwin Model is one of the very few pianos where I have seen gauge sizes go up, down, up, and down again. because we rarely see this. However, the tension across this anomaly (updnupdn) is quite smooth. I would go with the plate markings.
18 - 14
17 - 6
16.5 - 2
16 - 2
16.5 - 2
16 - 10
15.5 - 6
15 - 4
14.5 - 6
14 - 7
Tremaine Parsons RPT
Georgetown CA
(530) 333-9299
