Sent: 04-11-2025 00:51
Subject: Bass Bridge Hack job, clever fix to something not broken, or something else?
Took the rod out and still have some down bearing and was able to seat bridge pins back down all the way into bridge. Not sure of it's original purpose but have found other evidence of this piano being an experimental playground of sorts.
Joshua Sharp
Sent: 04-10-2025 08:49
Do you have any idea what the downbearing would be without the rod? If negative downbearing without the rod, that's probably why it was installed. What is the downbearing like with the rod? If excessive, that could also choke the sound and possibly make the tenor sound worse (curious what the tenor downbearing looks like?).
Sent: 04-09-2025 22:39
Too clever x .5
I've never seen the 'drift" reversed between the bichords and monochords before. More cleverness?
Sent: 04-09-2025 20:29
I have been treating the verdigris with fomblin so far with good success just curious about the rod and the only thing I can think of is adding down bearing though the bass is muddy and zero sustain so obv it didn't work
Joshua Sharp
Sent: 04-09-2025 19:54
I've seen (in pictures, not in person) bridge or center pins used in a similar fashion.
As for the verdigris, since you're tinkering anyway: try treating it with Fantastick. There was a journal article on this recently.
