Yes i can Peter.
The sanding pad is a German Diamond imbedded circular disk that removes metal without creating heat. Its lightweight, controllable, and see through which helps prevent the accidental removal of too much pin which can easily happen with bulky sanders. BTW, even if the pin is warm to the touch after sanding, it has begun the thermal expansion of the wood which weakens it. Something you don't, want especially maple.
All the elements are known, and yet no combination there of creates life. Yet we are here.
Sent: 08-21-2023 16:14
Subject: Bridge Pin height
Chris,
Can you elaborate on this self cooling sanding pad?
Sent: 08-21-2023 14:05
I just drill to the top of the drill bit flutes, pound the pin to the bottom of the hole, then use a self cooling sanding pad for a drill so the pins don't get hot to level the tops.
Sent: 8/21/2023 1:17:00 PM
Subject: RE: Bridge Pin height
I use the same method as David Hughes, but leave ~5/32" protruding. This allows just a bit more to secure the strings.
At 1/8" the monochords have a tendency to jump off while stringing. I like to have them a bit above the core wire.
It is easiest if a drill stop is used to drill to a uniform depth and drive the pins until they bottom out.
Dave Conte, RPT
Piano Technician in Residence
The University of Tennessee
College of Music
Knoxville TN
(817) 307-5656
Owner: Rocky Top Piano
Sent: 08-21-2023 06:55
I always drove a 1" bridge pin 7/8" into the bridge, so that 1/8" protruded.
David G. Hughes, RPT
Baltimore Chapter
David Hughes RPT
Vintage Case Parts
Glyndon MD
(443) 522-2201
