I've often wondered if there is a reasonable explanation for manufacturers' universal neglect of finishing the two most vulnerable parts of the bellywork of a grand: the bridges and the damper wire guide rail. Is there some perceived danger of warping? I don't see it. Since we technicians see the result of similar spillage on an almost daily basis, from our point of view the calculus of risk and reward is definitely skewed in the direction of finishing these parts which I will always do if I have the piano in the shop for restringing. We can make them functionally "good as new" but it's often difficult to make them look that way
For general clean up I keep a spray bottle of water with a dollop of dish detergent and ammonia. The sheer volume of different remedies available for cleaning up crud is a testimony either to the hopelessness of the endeavor (the crud always wins in the end) or the gullibility of the general public.
Cecil Snyder RPT
Torrance CA
(310) 542-7108
Sent: 05-14-2023 18:04
Subject: Bridge stain removal
If you get the wood wet with any water-based cleaner, it will swell the surface a little. Finishers often do this with water, let it dry, and then sand it smooth again. That makes the surface less apt to raise the grain when doing the final finishing coats. If you use something like alcohol, it might have the same effect as water because it has water in it. It might make the stain soak into the wood more than it already has. I doubt that the stain will ever be totally removed.
I don't know if raising the grain is going to affect the bridge function when it dries. Adding a finish over the area might affect it as well. Or maybe not. I do know that once I tried using epoxy putty on a bridge, or some kind of plastic, and the tone died. You want the wood in contact with the string to be firm and not rubbery.
Alternatively, you "could" route out the section of the bridge and add a new cap. Or use some touchup color to paint over the dark areas.
I got a lot of information by Googling "Removing Wine Stains from Wood".
Many possibilities..
