I work for a Bechstein dealer, so I've had to learn to use this system. Once you understand it, it's fairly simple and very easy to fine adjust.
I'm not sure the real names, but this is how I describe/understand it.
You have a steel frame screwed to the cheek block. Two screw on the underside lock position fore and aft.
Brass position adjustment - Pushes/pulls the framer fore and aft for strike point adjustment. Similar to old Steinways.
Brass Pressure block w/roller - This moves up and down to adjust pressure on the keyframe ends. The roller allows low friction shifting
What looks like a capstan is really just a pin. It gives the adjustment screw something to push against.
Adjustment screw - This is accessed from the front of the key block. All the ones I've seen are 3mm Allen screws. The other end is machined as a wedge. As you push the screw further into the block, the wedge will push against the capstan-like pin, pushing the entire block down. This allows very fine control over how much pressure is on the key frame ends.
Keep in mind, this is on a new instrument, they may have been a bit different a few years ago.
Hope this helps
Tom Dowell
Hulbert Piano
tom@hulbertpiano.com262-221-0792
