  • 1.  Capstan Boat
    Posted 30 days ago
    I'm sure many people have their own version of this but here's my newest.  With this one the small lead is the handle and allows you to insert it easily from the proximal side of the wippen.  The screw is adjustable up and down (of course).  The screw is threaded into a let-off button.  Once inserted to the desired position you can index with a pencil around the front of the popsicle stick on the key so you can find easily reestablish your position once the stack is removed.  Since I frequently move capstans (and always turn slanted capstans to 90 degrees), I wanted a boat that was easier to handle and index.  (of course I sealed the small key lead with lacquer).  We have to safeguard ourselves from unwanted toxins--too late...
  • 2.  RE: Capstan Boat
    Posted 30 days ago
    Dave
    I'm sorry, but I don't quite understand what this tool is supposed to do?  What does the screw on the let off button do?
  • 3.  RE: Capstan Boat
    Posted 30 days ago
    The tool is for determining a new capstan position and the screw is to adjust the blow distance.
  • 4.  RE: Capstan Boat
    Posted 30 days ago
    I am afraid of Lead poisoning, so i'm going to use lead as a handle, then protect myself with a lacquer coating.
    Why not just use a wood dowel for a handle?
    "Where Tone is Key"
    Piano Designer and Maker
    Designer of Inertia Touch Wave
  • 5.  RE: Capstan Boat
    Posted 30 days ago
    No reason, it's what was around that was the right size.  You can use what you want.
  • 6.  RE: Capstan Boat
    Posted 30 days ago
    That's exactly how I designed my capstan locator tool.  Quick and easy to find the right capstan position.
    Tom Servinsky
    Director/Conductor- Academy Orchestra
    Managing Conductor-Treasure Coast Youth Symphony
    Keyboardist- Beatles Re-Imagined
    Pianist with TLC Jazz Duo
    tompiano@tomservinsky.com
    772 221 1011 office
    772 260 7110 cell
  • 7.  RE: Capstan Boat
    Posted 30 days ago
    Excellent tool. So simple and functional. Thanks for sharing.
    Stewart
  • 8.  RE: Capstan Boat
    Posted 30 days ago
    Wouldn't it be more fun and entertaining to use a……
    Rocker capstan boat?
    Scott Cole, RPT
    rvpianotuner.com
    Talent, OR
    (541-601-9033
