Ok if you push the KR up to .5 then you will likely want a17mm knuckle. Use the same protocol I outlined to determine that. Sample using a 17mm shank with the hammers you are using and a FW of 85% of FW max and see if you can get a BW of 37 grams +/- 1g.
Sent: 08-15-2024 12:04
Subject: Capstan line from keys 1-88 is not even with the key balance pins. Should it be?
Thanks David for your input.
I have been measuring the distance ratio using the formula (Blow-Letoff) / (Dip-Aftertouch) = AR
I just now measured the AR using David's suggested technique of using two nickels. I have the Stanwood measuring table, which I used for the measurement.
This is for a 1922 Steinway O. I had previously relocated the capstans on all the C-notes, which I used for test notes, following David Love's protocol for determining the proper hammer weight at a 38 balanceweight. Now, I am working on relocating the rest of the capstans. The keys on this Steinway O did not have many weights in the keys. And it currently has newish Abel shanks with16mm knuckles. (I have not yet evaluated the Steinway L that I mentioned, which has lots of weights in the keys.)
AR Measurements for original angled capstan line, using two nickels:
Key #1 Ratio: .485 ; Key #88 Ratio: .475
AR Measurement for New Capstan position, using two nickels:
Key #1 Ratio: .50 ; Key #88 Ratio: .50
As I wrote before, moving the capstan line will also take the key ratio closer to 2 to 1. The key ratio will end up 240mm from front of key to balance pin, and 115mm from balance pin to capstan center, a .48 ratio. Key ratio with current angled capstans is 240mm and 110-111mm, a .46 ratio.
Joe Burros
Cell: 646-410-7174
jbcello@gmail.com
www.fmi-newengland.com
Sent: 08-15-2024 10:23
This illustrates one of the problems in this entire arena. The 4.6 to 4.7 action ratio in most methods of measuring the action ratio would be extremely low. It would not result in excess leading or an action that plays like a truck. Quite the contrary.
Similarly, Joe's method of measuring the key ratio, as we can see, is inconsistent with the proper way of measuring distance ratios, and I would guess that if you asked five people in this list how they measure the key ratio, you would get five different answers.
This is where using a weight based system Is sometimes easier and more consistent. I would suggest that Joe use the Stanwood method of measuring the key ratio. That method would be to put the key on a scale as if you're measuring the front weight, tare the scale (set it to zero), and then put two nickels, one nickel on either side of the capstan (a nickel weighs 5 g) and read the display. You should get a reading of something like -5.to -5.5 or something like that. A reading of -5 means the key ratio is 2:1. Do that at the both ends of the scale and tell us what it is.
On most pianos the AR is influenced most by the KR and the knuckle placement. In the Steinway accelerated action era you generally have a high KR combined with a 16 mm knuckle hanging. Bad combination. Removing lead near the balance rail will not lower the inertia (myth). It will simply increase the balance weight. Not a good solution.
The only solutions are: remove weight from the hammers (probably can't do that adequately), change the knuckle placement, and or change the capstan location. On the Steinway I'm working on I had to do all three and because the KR was so bad, I had to move the capstan to the very front of the wippen heel which then required me to add a strip of felt to the heel so the capstan didn't contract the wood edge. Even then, I could only reduce the KR to .52 so the hammers still needed to be fairly light even with a17 mm knuckle.
This is a Stein-was that resulted from the Stein-way and something that needs to be modified.
Sent: 08-14-2024 18:32
I have a 70's L here (Accel Action) with 4.6 to 4.7 varying throughout. A ton of lead in the keys, and plays like a truck. Actually feels better when I remove some of the lead near the BR. The capstan line varies up to 1.5mm randomly.
Sent: 08-14-2024 18:05
Joe
You say the center of the capstan hole is off center of the wippen heel. But where does the top of the capstan sit on the wippen heel? Even at that, a 1 or 1.5 mm discrepancy is not worth redrilling the holes. By the time you plug the old holes and drill new ones, the difference in wood might make the drill bit wander off course, anyway.
My suggestion is to leave well enough alone.
Sent: 8/14/2024 4:08:00 PM
Subject: RE: Capstan line from keys 1-88 is not even with the key balance pins. Should it be?
Hey George Davis, thanks for the tip about measuring. I was measuring from the top of the balance pin, which like you said is not accurate. So, on the lower bass keys, measuring from the bottom of the balance pin to the center of the capstan hole is 109.0-109.5mm. On the upper treble keys this distance is 108.0mm, about 1 to 1.5mm shorter.
Then, as far as where the capstan center lines up with the wippen heal, on the bass side, the center of the capstan hole is 1-2mm further back into the heel of the wippen, than where it lines up with the upper treble wippen heal.
So, the two measurement discrepancies above pretty much match up, which is great. It seems like the thing to do is to strike the new capstan line, so that it meets the wippen heal in the same place in the treble and the bass, in order to achieve a matching action ratio from keys 1-88.
Does this seem right to everyone?
Joe Burros
Cell: 646-410-7174
jbcello@gmail.com
Sent: 08-14-2024 15:10
Agreed, within reason. The action I worked on had gross inconsistencies everywhere. Post WWI piano.
I had to get things straightened out before considering going any further.
But, if Joe is talking about graduated key lengths, this would change accordingly.
Dave Conte, RPT
Piano Technician in Residence
The University of Tennessee
College of Music
Knoxville TN
(817) 307-5656
Owner: Rocky Top Piano
Sent: 08-14-2024 13:29
Just one comment, a slightly changing KR is not the end of the world. It's not unusual to find this. I have a Steinway B in the shop (1970s accelerated action type) that has a horrible key ratio, 5.5 in the bass but it graduates down to about 5.4 in the treble (still horrible). Other than having to move the capstan because it's simply to0 high, the fact that it changes across the scale doesn't really worry me and I would not consider it a problem. If the ratio were a more reasonable 5.2 graduating to 5.1, say, I wouldn't bother to change it at all. On an older piano with slanted capstans I would because I prefer them to be 90 degrees to the key but not because the ratio changed. That change will all get teased out in the smoothing of the SWs and FWs and the difference in regulation is not significant.
Techs get hung up on these small inconsistencies, but I think that just goes with the territory (physical and psychological). Don't sweat the small stuff, or is it the devil is in the details. Life is full of contradictory advice. Choose your battles.
