This whole thread is under 'review' by the PTG because I somehow 'offended' someone, and I did not mean to do so because I kept the name of the app totally confidential. I apologize. I have 'great' relationships with all the underlying people who were quietly behind the scenes collecting the data and even the app rep who appreciated the hard work involved. No offense was taken. The purpose of this thread was to do the hard work to show the data statistically.
I hope the committee does not take it down because many of you have had great responses.
Thank you.
Steve N.
Sent: 02-14-2024 15:32
Subject: Challenging mic vs sensor with independent measurements
Peter, for the most part, my interest in this is not the issues you raise. What piqued my interest was that early on in the discussion of the PianoSens, Steve N. asserted, perhaps in a moment of hyperbole, that in some instances there were differences in frequencies between the string's signals and those emanating from the soundboard that were more than trivial. This could present a problem, perfect unisons of a piano that's not in tune with itself are not of much use. Yesterday Steve N. stated that in fact the frequencies both from the string and the soundboard are indeed the same. Okay, I'll accept that at face value. Problem solved. It was never a challenge of whether the PianoSens "works" or not, I'm sure it does.
For piano tuners, the objective test that we have created a TET are the interval checks. If tuned correctly we will get a smooth progression of beat rates as we move away from the center of the piano. Unlike any readings we get from an ETD regardless of how it gets its input, the interval tests are a direct aural reading of the differences between coincident partials, no algorithms no indirect calculations. It seems to me that that should be the starting point for any evaluation of a piano tuning. Important as unisons are, they are secondary to the tuning of the instrument as a whole. That's why I requested it a month ago, I think it should be checked off the list first, then on to the unisons etc. I understand that the PianoSens doesn't calculated tunings, it's merely an input device, but the difference between reading the string vs. reading the signal from the soundboard I think is enough to verify the tuning first. Had this been done in the beginning I wouldn't have had much to say.
As far as the issue of ascertaining the difference between string and soundboard, which Nathan takes up, it does seem problematic. Perhaps a statistical analysis would give a very educated guess. Still the most direct way would be to evaluate the results of a tuning based upon the string's signal alone using the interval checks, if there is an unevenness, that indicates a disparity if not, then we're golden using that method.
Sent: 02-14-2024 12:46
Steve R:
Probably the best thing one could do to resolve whether the transduction from string to sound changes any of the partial frequencies, would be to take a _bunch_ of mic readings at different locations and average them (or take the mean, or whatever you decide is more significant -- I haven't thought through it TBH). You could use an offline tool or just take the readings off the app, I kinda doubt it would make a difference when you're averaging a large # of them. You could then compare that average with readings from the string sensor, and see if there's any bias between the two. I certainly don't expect anyone to do that work for us, I'm just offering a potential experiment design.
I agree with your basic question, as I understand it. In my own own words, I would phrase it as "the string sensor has less variance than microphone readings at different locations/times, but is there any bias between the two? And if so, which most closely matches what we actually hear?"
Edit: Apologies if this is already covered in the current data, I am still digesting that.
Nathan Monteleone RPT
Fort Worth TX
(817) 675-9494
nbmont@gmail.com
Sent: 02-13-2024 16:05
Okay, thank you, the frequencies do not change at all during the transmission through the soundboard. I'll accept your word on that, out of genuine curiosity, how does one verify this?
The reason it is consequential is that the ultimate arbiter is our ears, we don't hear the strings directly we hear what is coming out of the soundboard. I'm sorry that this so irritates you. But thanks for your answer.
Sent: 02-13-2024 15:33
Frequencies are set into motion as standing waves on the string, as they are the SOURCE. The soundboard and acoustic waves color this with up to 450,000 eigenmodes of spatial color (ref). The frequencies are not changing but the ability to discern and resolve them do change. Spectral analysis at the highest level is needed.
You still miss the most consequential aspect. You have significant variances with the mic. Which mic reading variant do you trust? Why? Is it consequential to YOU? If not, no need to keep debating. Just let it go. Just use your preferred app and your preferred mic and call it a day. I suggest you now let others write their findings, coming up today. Give some room for others, please.
Steve N.
Sent: 2/13/2024 3:28:00 PM
Subject: RE: Challenging mic vs sensor with independent measurements
Steve, variance using the mic aside, was that an answer to my question? This test is using input from different sources, how do you verify that the composition -frequencies- of the two are the same? It seems that this would be essential for cross comparison.
Sent: 02-13-2024 14:53
1) Variance using the mic vs invariance using the sensor. It is an already understood phenomenon that moving the mic causes changes in the resolution process of determining an accurate reading of frequencies partials from position to position.
2) The actual reported variance by the app itself vs what the representative says the app reported. The independent study showed large variance in the app itself by moving the mic. The representative cherry picked a few partials per note that lined up with virtually the same readings in the app with the mic vs the sensor to make it look inconsequential. It is already understood that some partials on some notes on some pianos will not vary much in frequency readings with mic positional changes, but some will. Now we have a statistical study that is needed. So an independent did a study and collected the data using the same model piano as the representative used. That study needed to be done in order to more comprehensively show the representative's results were not comprehensive and indeed were very consequential.
3) In other words, if you are selling a $1000 app, it is in your best interest to say that there is no need to buy a $600 sensor in addition because it makes no difference. Well, the independent study shows otherwise. It is up to the reader to determine, from the numbers, whether it is consequential or not. It is not up to an app representative to do that.
4) The representative has dismissed a user for stating how much various apps were seeing significantly reduced jitter, by saying that the user was not experienced with apps and was not using his app. So what then happened? Later today you will see some new reports by this very user who gathered a room full of expert app users and evaluated this on a grand piano. Stay tuned (pun intended).
Steve N.
Steven Norsworthy
Cardiff By The Sea CA
(619) 964-0101
Sent: 02-13-2024 14:33
Steve, the PianoSens is measuring frequencies emanating from the string while the mic is measuring frequencies emanating from the soundboard, how do you verify that the two are identical?
Sent: 02-13-2024 09:09
MATLAB is the international standard, de facto
Sent: 2/13/2024 8:58:00 AM
Have you ever considered Comsol Multiphysics as a platform for measurement?
