Castung sounds like a variant of tung oil.
Sent: 12-26-2024 01:41
Subject: Charles Stieff grand scale 37
I have never used (or heard of) Benite. So I googled it. It is made from Mineral Spirits, Castung, Linseed oil, Naptha. The warnings for exposure are quite nasty, lots of ventilation needed, skin exposure, toxicity, cancer, etc. If I wanted to create a vapor barrier to limit moisture travel to and from the pinblock, I would think an industrial epoxy like West systems would be the way to go.
William Truitt RPT
Bridgewater NH
(603) 744-2277
Sent: 12-25-2024 21:20
Marine sealer available from Grizzly.
Sent: 12-25-2024 18:26
Parker,
Never heard of Benite. Any details?
Sent: 12-24-2024 15:24
That is also an argument for applying a good finish to the pinblock. I like to use Benite followed by marine varnish (McCloskey)
Sent: 12-24-2024 10:15
In short, I have nothing to offer on the scale, but a couple comments on side notes of this thread.
Arledge just has some problems with some of his machines for a number of weeks. I'm sure this has put him behind- I had a couple dead strings on my last restringing job and he explained that the delay in getting me replacements was due to this.
In regards to the tuning stability issue, this is exactly what John Parham theorizes, and he has done some great experiments that suggest that the pinblock has a lot to do with stability. It makes me wonder if multi-laminate boards like Delignit or Falconwood have the advantage of greater stability since they are less affected by humidity?
Sent: 12-24-2024 08:01
I have had a bit of difficulty contacting James of late. Seems he is going in other directions these days (though I can't absolutely confirm this).
At any rate on a side note, I have long theorized that much tuning instability (unisons primarily) has to do with the pinblock expansion/contraction. As I have tunedvthis piano for a number of years I have been significantly impressed with its seasonal stability (in comparison to many other pianos) of course not knowing that the tuning pins were primarily being held by the plate rather than just the pinblock. In addition to this the extremely sloppy existing stringing job had MANY pins so deep that the coils were jammed on to the plate with quite a few overlapping coils. Pins were extremely tight, but tight in the plate. It now appears that the tuning stability came largely from this anomaly.
I find this to be rather interesting. 🤔
Sent: 12-23-2024 19:28
Try James Arledge Strings. I replaced all of the bass strings including 21 wound strings after the bass break sitting above the other bass strings. This was on a Chas Stieff Parlor Grand. After I did a tracing and measured/mic ed the strings we discovered he did have the scale after all. Lots of these pianos can be found up in MD and VA area
