Sco
You might want to see if Kathy is willing to sell hers, given that a 30 year old, seldom used tool would probably be of better quality than most of what you'd find now, at least at anywhere near reasonable $.
However, if this item
https://www.ebay.com/itm/165217078365
is actually in the condition represented - Armstrong #64-352- I would buy it and worry about what to do with it later. Just as with quality hygrometers, there's a world of difference between 'thinking' you know something and having verification. Never mind having to justify something to a customer. Let's say you came upon a piano with a potential warrantee issue involving loose pins. What are you going to do? Tell the dealer that "they feel pretty loose", or are you able to tell them a number, (measured correctly)?
Only Wim has perfect torque. The rest of us are guessing.
Addendum:
you could also look at this:
https://www.mcmaster.com/5718A46/
David Skolnik [RPT]
Hastings-on-Hudson NY
(917) 589-2625
Sent: 05-13-2023 15:46
Subject: current torque wrench/gauge recommendations?
Scott
I didn't realize the one from the supply house is now $250. I can't remember what I paid for mine because it was so long ago, but it has served me well over the years.
Yes, I can tell how tight a pin is, but I use it to show customers how tight the pins are. I tell them ahead of time what the numbers mean, and how tight a pin should be. Then I show them with the numbers with the gauge. It's a very easy way to tell them they need a new pin block.
It looks like the Park tool will work, but you will need to buy a ratchet Star head tuning tip.
