I would appreciate suggestions for the cause of a metallic click associated with the damper pedal of a Kawai 6-foot CA-40N that I service. I have isolated the problem to the external trapwork. If I put my hand on the brass push rod from the pedal I can feel the "click", and if I apply some horizontal pressure halfway up the push rod while operating the pedal the noise/click goes away. It's true that the lyre posts have come unglued, but the noise is a metallic click – not a wood creak.
I hope/figure that when I return in a couple days and remove the trapwork and disassemble the pedals in the lyre, I will see an issue with the metal damper pedal and its hinge rod. Agree? Can anyone suggest other possible causes that I should watch for? The two metal lyre braces seem to be well attached. The click occurs with/without the little rubber boot being at the bottom of the brass push rod.
Thanks in advance. Regards, Norman
potomacpiano@verizon.nethttps://potomacpiano.com(301) 983.9321
