Rex,
Here is what I think the sequence should be for regulating pianos with spoon-equipped damper underlevers:
1) Get the underlever bodies a uniform distance (height) above the keybed. This is done first to ensure a uniform elevation of the sostenuto tabs during subsequent regulation. Regulate the underlever bodies by placing a jig of suitable height on the keybed and resting each underlever on it. Loosen the topflange setscrew at the damper wire and settle the body on the jig, while simultaneously settling the damper head felt into the unison. Tighten the screw. Now all the bodies and sostenuto tabs will be in a straight line.
2) Regulate the spoons to the keytails. Establish a desired lift timing for a sample underlever by bending its spoon up/down. Set an adjustable gauge to this setting. Place the gauge on the keybed and regulate (bend) all the spoons to this elevation. Now all the underlevers will be timed to the keys uniformly.
3) Now regulate the underlevers/damper tray to the sustain pedal for uniform lift.. Adjust the individual underlever capstans so that all underlevers lift uniformly and level using the sustain pedal.
4) Lastly, regulate the sostenuto blade to the tabs on the underlevers.
David G. Hughes, RPT
David Hughes RPT
Vintage Case Parts
Glyndon MD
(443) 522-2201
