James,
Yes, the first for the university as far as I can tell. Not the first I have personally installed.
The issue is not generally too high, but too low humidity based on what I saw with this piano.
Yes, in a perfect world, or institution, this would be a no-brainer to fix the problem globally at the
HVAC level. But this is in an older building and not going to get funded.
Fortunately, only 9 pianos reside in that building, two of which are the in the concert hall within
a climate controlled off-stage room.
The other 115 pianos are in the new music center building, which is climate controlled and has
pretty decent RH monitoring and control. But when it is taken off-line for service, it is a lot of extra
work.
Dave Conte
University of Tennessee
Knoxville TN
(817) 307-5656
Owner: Rocky Top Piano
Sent: 08-24-2022 20:25
Subject: Dampp Chaser/Piano Lifesaver System longevity
Dave Conte .. did you mean this is the first DC/PLS you ever installed at the University ? Keep in mind that these systems are good but will not fix all of the environment issues that exist in the space the piano is used in. You may need better HVAC and room humidification or dehumidification and the DC needs to be properly sized and placed for a large D. I have found the templates/blueprints from Dampp Chaser helpful for ordering and placement. As a rule here I typically order the higher wattage dehumidifiers
Sent: 08-24-2022 07:53
I just installed the first one for the University last week on a SS D
in the opera rehearsal room. Included the undercover
I had to recap the bridges on this 20 year old D due to climate issues.
This is a good test case to monitor and set a reminder for 5 year intervals in the future. .
Thanks for posting, Zeno.
Sent: 8/23/2022 9:34:00 PM
Subject: RE: Dampp Chaser/Piano Lifesaver System longevity
My own experience corroborates Kevin's numbers. We had failures with low-water warning sensors and heating rods and appear starting at around 25 years in service. At 30 years we began replacing them. A bonus is that the new systems all have power-on indicator lights which are always useful, and even more so during a pandemic.
Sent: 08-23-2022 13:07
First of all if there are any of the old "chrome" rods or those BROWN stats…NO BRAINER-replace!
My best guess is anything over 30 years old for sure…but personally…if you are assessing and thinking about it at this time, I would say 25 years is a pretty good "cut off". My logic is based on when will this even be considered or looked at in the future..??? If your budget will allow of course. Or you could (of course) start with all the oldest ones then have an "ASAP" list or "danger zone" list for systematic replacement in the near future. My 2 cents.
Kevin Fortenberry
Longview, TX 75602
806-778-3962
