However, if you buy one and the instructions tell you to connect things a certain way it's probably in your best interests to follow those instructions. If I'm wrong on that please LMK.
Sent: 09-29-2024 15:39
Subject: Dimmer for Key Easing Iron
Cobrun, FYI, I think that the 110 volt polarized plug came into use more than 50 years ago, and later came the additional ground prong. I'm not licensed or certified to give electrical advice, but as an amateur I can think of a few items that you might want to look into.
(a) For a plain key easing iron with no on/off switch, I would think that plug polarity is not significant. (b) If your iron or rheostat has an on/off switch, then from a safety perspective I would assume that the hot wire (small prong on the plug) would be connected to the switch side of the device. (c) If the device has a chassis associated with it then I assume that any modern device will use a three-prong plug to make a ground available.
Regards, Norman
Sent: 09-28-2024 15:46
Patrick, thanks, maybe you are right – just not my experience with most (90+ percent) front rail pin bushing tightness issues. Mine is the same time frame as you, but likely not the depth of your experience. A solid push left and up/down several times, and then a solid push right with the same motion. (Don't test how strong you are!) You can feel the free play open up. No callbacks on my end – perhaps just luck? Maybe the DC climate? Also the problem probably usually develops from a lack of play at the extremes, and if the piano is newly back in service normal play should keep it free. Some pianos more so than others can be a pain to remove the keys, of course – this approach can certainly be worth a first try in my opinion. Regards, Norman
Sent: 09-28-2024 14:51
Norman, in my 45 years experience, wiggling and rubbing keys up & down is (here in our New England seasons) a very temporary fix. Sometimes depending on key easing pliers is an impermanent fix too. Remove the fallboard and key up stop rail, and see what's really going on.The key pins may have rust or burrs, or need sticky tarnish removed. Iron the bushings, and possibly dust some fine powder teflon on if advisable.
I have also run into Baldwin uprights from the 1980s that have excessively long balance &/or front rail bushings. An Exacto knife with a chisel blade can trim them to length.
Having all the necessary tools on hand allows one to deal with these common problems.
Sent: 09-28-2024 11:45
Cobrun, I just want to concur with Wim's comments – I keep a key easing pliers in my case.
Mostly my customers might only have a few (white) keys that are noticeably sticking. Excuse me if this is obvious, but 90+ percent of the time if you work those few keys up/down, with a little side pressure, it "fixes" the problem without major surgery. I explain all to my customer, including showing them how to work the key up/down themselves if the stickiness returns. I've never had a customer be dissatisfied with this approach. Along with a minimal or no charge for the few minutes of work, chalk it up to establishing customer loyalty. Regards, Norman.
Sent: 09-28-2024 10:43
Overkill. What happens when you tell your electrical engineer dad that you need a rheostat.
Deb Legg
Sent: 9/27/2024 5:32:00 PM
Subject: RE: Dimmer for Key Easing Iron
Sometimes I wish I had a heavier duty 20 or 25 amp controller. They are more expensive but will allow a lower temp. Move quickly to avoid
burning and do not use more than a 25 watt iron.
Sent: 09-27-2024 11:19
I use the same one as Parker and it seems plenty accurate for our use. (Precision electronic soldering is another matter and I use a completely different iron setup for that.) Using an infrared thermometer to check the settings and mark them on the dial helps with accuracy as different soldering irons have different heat curves.
Allan Gilreath, RPT
Calhoun, GA
706-602-7667
Sent: 09-27-2024 09:33
I use a router speed control from Harbor Freight around $16
Sent: 09-27-2024 08:10
https://www.mohawk-finishing.com/products/wood-touch-up-repair/burn-ins/burn-in-knife-electric-heat-control-unit/
I have another version of this that I've used for decades. Apparently you need a customer number to purchase from Mohawk online. There is a local hardware store that sells Mohawk products, so I don't need a customer number.
