Happy Thanksgiving to you all as well. I am very thankful for this community, I have learned so much from you all!
Sent: 11-22-2023 17:26
Subject: Downbearing measurements without strings
Certainly one should exercise caution that what is said may be misinterpreted and used against you later 🤪. Especially when it comes to plate bending.
But the reality is that plates do flex and even the best efforts to avoid any and all plate flexing are probably futile and without real risk. Even Steinway uses nose bolts to tweak bearing by bending the plate (usually down) while the official position, and rightfully so to avoid what you refer to, is that plates should not be flexed.
I have made *small* adjustments to the bearing on several occasions with the benefit of WNG plate bolts and still sleep soundly to the degree that my aging sleep cycles allow. But we certainly don't want to rely on that method as a means to compensate for poor bridge cap or pinblock accuracy.
Happy Thanksgiving all.
Sent: 11-22-2023 08:52
David Love (reply to your post #14),
Yes, I understand your position. I was merely stating some facts as I see them about setting downward string pressure on soundboards. For the experienced, this obvious - not all participants of this discussion may be experienced. What I think we need to be careful of is implying that the WN&G plate bolts can be used to "set bearing". Briefly, the simple visual analogy is a car's hood. It hinges up near the windshield. As the hood closes it becomes nearer the rear of the engine (and would apply more pressure) long before it nears the grill on the front of the car.
A piano plate is buckled to the pinblock, and this is an elevation we do not wish to alter - primarily for proper action performance. It is a hinge point. If we want to bend the plate (I don't), we can raise or lower the rear of the plate to "set downbearing". The condition will arise immediately that when the plate is lowered, for instance, the downbearing will increase dramatically at note 88 long before any change is affected at note 1. All the notes in between are at the unrefined mercy of the procedure.
On the general topic of how much downbearing is "just right" for any piano, bear in mind manufacturers build oodles of pianos as experiments (in spite of the best mathematic calculations), changing only one element of the downbearing equation in each experiment, and then they aurally evaluate each experiment. They enjoy the luxury of being able do this. As a rebuilder, we attempt to do the same experiments, only with less candidates to experiment with. Ultimately we just have to buckle down and rebuild lots of pianos to come up with a soundboard structure and a downbearing formula that gives us the results we're hoping for. Unfortunately life is too short for the small shop operator - we rebuild hundreds of pianos; manufacturers build hundreds of thousands of pianos. Nonetheless, everyone participating in this discussion, and beyond, does the best he/she can in the time that is granted to us! :-)
David Hughes RPT
Vintage Case Parts
Glyndon MD
(443) 522-2201
Sent: 11-22-2023 01:42
I think what I said was that they are " a godsend for tweaking the bearing in situ". That's a far cry from using them to set bearing. They are, however, used to set the plate height and function in the place of soundboard dowels. Downswing is more a function of bridge height, though there are some other factors like aliquots etc
Sent: 11-21-2023 21:41
David Love and Others,
I do not believe the intent of the WN&G plate perimeter bolts is to set downbearing on a soundboard. They are intended to capture the elevation of a plate above the soundboard once the desired downbearing has been achieved between the height of the bridges and the elevation(s) of the hitch pin panels on the plate. This is exactly what is performed at the Mason & Hamlin factory, utilizing the WN&G plate bolts.
Using these bolts to "set" downbearing will produce (only) a predominantly vertical global movement. It is common practice in piano manufacture and rebuilding to set different amounts of downbearing at different locations across the bridge caps. Adjusting a plate globally in the vertical plane (e.g.using the WN&G plate bolts) will not acheive this goal. One area may improve to the detriment of another, and vice versa.
I respectfully understand where you're going with this discussion, but it may not be wise, or completely thorough, to suggest using any plate suspension system to finesse downbearing. This must always be done by either adjusting (planing) the heights of the bridges relative to the plate elevation, or by using a vertical hitch pin whereby the strings me be slid up and down the pin to adjust string pressure on the soundboard from one area to another irrespective of global plate elevation.
David Hughes RPT
Vintage Case Parts
Glyndon MD
(443) 522-2201
Sent: 11-21-2023 15:55
Z Huang wrote: I still don't understand what level of down bearing is best. Soundboard tension, down bearing, string tension, what's the most rational relationship between. These three should be considered comprehensively, right? These three should be considered comprehensively, right? All these calculations are still based on the state of the soundboard. The state of the soundboard is the basis of these calculations. Can I understand it this way? Therefore, according to the state of the soundboard, calculate the tension of the soundboard, adjust the relative height of the piano cast iron plate, and fine-tune the relative height of the cast iron plate (the height of Duplex-Skalen) according to the down bearing.
Ask 10 different techs and you'll probably get 10 different answers. But the short answer is yes, all these things should be considered comprehensively. Typically, when a soundboard is being designed, the total downbearing is taken into consideration when designing the load bearing properties (i.e. the rib scale) to support the load. The basic idea is that it must support the load but not be too stiff or too massive or the energy from the strings won't be able to move it adequately to generate ample enough pressure waves in the air and the piano will lack power, even if it exhibits good sustain.
Typically, the boards have been designed to compress about 50-60% under load. That compression stiffens the board effectively without building in additional mass in, say, the ribs or the panel. Each soundboard designer will develop their own standard and that % can vary with a number of things including string tensions, downbearing settings, amount of crown, personal impedance preferences etc. Each one should be considered before making a final call and all these numbers come about with some testing, though there are general guidelines.
On older soundboards the typical approach is to compress it as much as you can to try and achieve the requisite stiffness, as close as you had before, that has been lost due to age and accompanying loss of crown. The limit has traditionally been not to compress the board to the degree that you "oil can" it, or push it past flat to concave (from the top). If the board does not have adequate crown then you replace the board. Trying to rebuild crown is usually not very effective (or worth the effort).
The Pythagorean method outlined is one way to put a practical limit on down bearing settings. It requires measuring the crown (not always so easy) and then determining at what bearing the board will go flat. Keep in mind that downbeaing never gets to zero if the bearing is uniformly and positively set to begin with. If you understand the mathematical idea of "limits" you will have a better sense as to why. That's not to say that we don't see boards with negative bearing somewhere, but that must be because the bearing is positive somewhere else. The bearing aggregate across the entire board must always be positive if it starts positive.
All that being said, the WNG perimeter bolts are a godsend for tweaking the bearing in situ and I am a strong advocate of their use whether it's a new board or restringing over an old one. As Gravagne pionted out, by creating a small recess in the seating area of the perimeter bolt (usually about 6 mm is enough) you can avoid any problems that arise from it bottoming out before your desired settings are achieved, or before the plate contacts the board directly. Crating a guide for the forstner bit to keep it aligned is very simple and I'm glad to share my method if someone is interested.
Sent: 11-20-2023 12:53
Zhanxi Huang
Benxi
86-18741420582
