Do not apply a dark staining finishing oil! The stain you get might not be the color you want. There are oil and alcohol stains that will tint the wood to the appropriate color. If you apply them too light you can reapply up to the exact color you want, then apply an oil or other finish. Using only Watco (which is a good finish) might seal the wood too dark or too light.
After you get the exact color and texture you can apply whatever finish you want. I made a hammer recently and used an oil finish that gives my hammer a very smooth feel. Shellac has a slight, pleasant, rubbery feel and dries fast and can be reapplied or used over other finishes or removed. Polyester and epoxy finishes can be hard and smooth (I like my Charles Faulk hammer finish). I have not tried Spar varnish.
