Yes, Ethyl acetate is an oxygenated solvent, whereas Naptha is a hydrocarbon solvent. I figured since verigris is oxidized brass, i would try the oxygenated solvents and Ethyl acetate worked the best.
I became aware of the Wurlitzer simliar product just today during my phone call with Peter Grey.
Just Naptha by itself works ok, and adding the silicone improves, but adding the EA made a big improvement.
I've been using this formula for about a year now and the E.S.N. seems to be holding up.
"Where Tone is Key"
Sent: 05-19-2022 20:32
Subject: Ethyl's Silly Nap Centerpin Lube and Cleaner
Silicone and naphtha was the go to juice Wurlitzer used on their tight center pins. It's the Ethyl $%^& that is different. I guess, as per your description, it's the ingredient that cleans the verdigris.
It would be interesting to see how those flanges behave after 3 - 6 months.
