The curl of the wire should be perpendicular to the soundboard or parallel to the soundboard. Not because of soundboard physics, but because the hammer blow is perpendicular to the soundboard.
One way to accomplish this is to wrap the curl around the hitchpin and make the bend in the same plane. This will orient the curls parallel to the soundboard (and perpendicular to the hammer blow).
Another way is to cut the double length of wire and lay it on a flat surface, then make the bend for the hitchpin by grasping the mid-point with round nosed pliers and "folding" the wire over so both half curls are co-planar. This will orient the curls perpendicular to the soundboard (and parallel to the hammer blow).
For a single tie you could make the loop a little bit oversized, then observe the coil, grasp the mire with pliers near the loop and slightly twist the loop to make the coil perpendicular or parallel.
Sent: 02-04-2024 17:34
Subject: False beat in lower plain wire.
I am trying to "twist" my mind around all this. I just finished studying the two articles from '08. As I read them, twist is neither a good or a bad thing, i.e, has little of no effect on false beats. However, it is important, in the longer and lower tension strings, to make the hitchpin loop parallel or perpendicular to the residual curl of the wire. So my takeaway is that it is best to cut the wire to length, then let the wire recurl before making the hitchpin bend. Is that the understanding of others?
The articles say that In the upper treble, false beats are more often the result of bad terminations- particularly bridgepins located in holes that have become flared at the top allowing the pin to vibrate excessively as well as strings that are not seated precisely to the bridgecap. This is exactly my experience.
By the way, I have had some good luck in reducing/eliminating upper treble false beats by scaling to keep tension high as possible (in the 170s and 180s). Inharmonicity goes up somewhat but I don't care about that so much. My theory is that the added tension helps with all of the above issues. Am I on the right track?
Ted Kidwell, RPT, CTE
KidwellPianoworks
4782 Pasadena Ave.
Sacramento, CA 95841
Sent: 02-03-2024 17:28
This new thought on the origin of this type of false beat has my mind spinning. Can't wait to get over to the one B and see if I try this remedy. Fingers crossed that this solves this issue. Fascinating thread!!!!!
Tom Servinsky
Director/Conductor- Academy Orchestra
Managing Conductor-Treasure Coast Youth Symphony
Keyboardist- Beatles Re-Imagined
Pianist with TLC Jazz Duo
tompiano@tomservinsky.com
772 221 1011 office
772 260 7110 cell
Sent: 2/3/2024 11:20:00 AM
Subject: RE: False beat in lower plain wire.
Yes, those low tenor unisons are the most difficult to nail, largely due to their low tension (less movement of the pin causes more movement of pitch), and any "junk" in the sound envelope makes the job that much harder.
Ed Sutton's suggestion of reading Ellis' article is a good one. You can access all the Journals online quite easily through the
Journal Archive, a project of the Education committee (the project having been led by Jason Cassel). That particular issue can be found
here.
My take on Ellis' experiment is that a bit of twist is a probably good thing when stringing. It is when an untwisted string is oriented so that the residual curl of the wire is at 45 degrees to horizontal (without twist) that false beats occur (and presumably lesser false beats would occur at orientations between 0 and 90 degrees).
At least that's how I read it at the time, and I come to the same conclusion in rereading it. IOW, if you are very careful not to introduce any twist while stringing, it is quite possible you are going to set the stage for false beats. Counterintuitive, but that's what seems to be shown by experiment.
Sent: 2/3/2024 9:03:00 AM
So far, no one has raised an issue. But I end up spending a lot more time of massaging the unison to find an acceptable tolerance.
Tom Servinsky
772 221 1011 office
772 260 7110 cell
Sent: 2/3/2024 7:49:00 AM
My question is: "Are musicians complaining about this 'false beat' or is it just something that annoys the tuner/tech?"
Sent: 02-02-2024 09:40
The article False Beats in Piano Strings – Part I by Jim Ellis,RPT, John Rhodes,RPT, James Arledge,RPT, and Darrell Fandrich,RPT in the August 2008 Journal describes false beats caused by the angle of the residual string coil arch relative to the plane of the hammer strike.
A residual coil arch at 0 or 90 degrees to the hammer strike does not produce false beats.
A residual coil arch at 45 degrees to the hammer strike produces clear false beats.
This effect is most pronounced in long, low tension strings such as the lowest plain wire notes of a Steinway B, duplicated on Ellis's monochord.
The first partial beat is generally so slow as to be inaudible, but higher partials can have pronounced false beats.
Twisting the string does not produce false beats if the combined front and rear twists produce a zero turn relative to the hammer strike, i.e +45 degrees on one end and -45 degrees on the other.
Thus, when stringing a piano it is desirable to orient the wire coil such that the hitch pin bend occurs in the plane of the residual coil, or errors exactly at 90 degrees to the residual coil.
Now, this is a suggestion by me (Ed Sutton): If, by loosening the wire you can see the arch of the residual coil, you might try putting in a counter twist (if possible) by resetting the coil on the tuning pin. With a lot of luck, this might duplicate Ellis's "front/back" twists well enough to reduce the false beats. Just a hypothesis.
