Hi,
1/2" is too thick....measure once...cut twice....
Kind regards.
Horace
On 6/29/2022 7:12 PM, Wim Blees via Piano Technicians Guild wrote:
> It does make sense to use a piece of end grain, but you'll want to use at least an inch of it 1/2" thick, imbedded and glued into the keyframe. You will need to do some chiseling to get it to fit.
> Original Message:
> Sent: 6/29/2022 9:44:00 PM
> From: Joe Wiencek
> Subject: Hardwood insert for shift lever
> List,
> I need to replace the hardwood insert on the key frame where it contacts the shift lever because it is all chewed up (Steinway B.) I was thinking that I should replace it with the end grain facing where the shift lever makes contact. Is there a reason I should choose another grain orientation?
> Thanks,
> Joe Wiencek
> NYC
> Reply to Sender :
https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=752527&SenderKey=728edbde-ad1a-4215-a26e-8c4633d58814>
> Reply to Discussion :
https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=752527>
> You are subscribed to "Pianotech" as
horace@horacegreeleypiano.com. To change your subscriptions, go to
http://my.ptg.org/preferences?section=Subscriptions. To unsubscribe from this community discussion, go to
http://my.ptg.org/HigherLogic/eGroups/Unsubscribe.aspx?UserKey=3feecf45-4a69-4cff-bbb2-fd6c7eaf0569&sKey=KeyRemoved&GroupKey=2bb4ebe8-4dba-4640-ae67-111903beaddf.>
Sent: 6/29/2022 10:13:00 PM
Subject: RE: Hardwood insert for shift lever
