Hi Joshua,
Man, you get into some interesting pianos. Personally I think it's great you're giving them some love and attention. Just remember, modern pianos are a lot easier to work on, so don't get discouraged in the process.
Based on your video, it looks like the eyelet screw adjusts let-off (how close the hammers get to the strings before moving on their own momentum), just like most uprights. Start regulating there after you replace whatever felt / leather / parts you're going to replace. I'd set let-off about 1/8" away from the strings, as this is an older style action.
After you set let-off, key dip is next. After key dip, I'd do hammer blow distance next. Both of these should adjust as normal. (There's plenty of material on how to do these things readily available.) Obviously that's not a complete list, but should get you started.
www.professional-piano-services.com------------------------------
