Sent: 09-20-2025 09:09
Subject: Help: Implementing the Equal Beating Temperament System in Practice
"The only place you can generate a beat at the fundamental (1st partial) is in a unison. Otherwise ALL intervals are producing beats at the 2nd partial and/or above."
We know what you probably meant, but that didn't come out right, did it?
2:1, 3:1, 4:1, 5:1, etc. are intervals generating beats with the first partial of the upper note.
Sent: 9/20/2025 8:29:00 AM
Subject: RE: Help: Implementing the Equal Beating Temperament System in Practice
Sent: 09-20-2025 07:45
Fundamental is the first partial.
Sent: 09-20-2025 00:00
The Importance of the 1st Partial
I wish to add to the current body of research by emphasising the importance of the 1st partial.
The Equal Beating Temperament System is based on the creation of 1 : 1 beat ratios. This is achieved by nullifying the difference between two beat rates via the production of equally beating intervals, i.e., the difference is 0 Hz. The nullification of the difference between any two Hz values naturally gives rise to beatless intervals and intact Unisons in this system. I have accounted for intact Unisons throughout my calculations, though it may not be obvious upon first inspection. This connects the Circular Harmonic System, the Equal Beating Victorian Temperament, the Equal Beating 5ths and 4ths Temperament System, and the Pure Octave Equal Beating Temperament. Intact Unisons are integral to the overall design of the Equal Beating Temperament System. It would be good to know what impact this has on the tuning of Unisons in practice.
There is also the inverse relationship between the Pythagorean Comma and inharmonicity. I will use the 2 : 1 Octave A3-A4 in Pure Octave Equal Beating Temperament to illustrate this relationship as it is directly connected to the 1st partial level.
When the Pythagorean Comma is present, the 2nd partial of A3 is flatter than the 1st partial of A4. If inharmonicity sharpens the 2nd partial of the lower note, the Pythagorean Comma becomes smaller. The reason for pointing this out is that a decrease in the size of the Pythagorean Comma decreases the beat rate of each 5th and 4th of the tuning chain theoretically. Now, the inharmonicity of the coincident partials of all the 5ths and 4ths of the tuning chain must also be taken into consideration to determine the uniform beat rate of that chain in practice. In this scenario, the 2 : 1 Octave A3-A4 is wider than pure by flattening A3 by an amount that is less than the Pythagorean Comma (Beatless: 2nd partial of A3 = 1st partial of A4), the 5ths are narrower than pure, and the 4ths are wider than pure on the 1st partial level.
If inharmonicity sharpens the 2nd partial of A3 by the same amount as the Pythagorean Comma, we find ourselves in a unique scenario where A3 is flattened by the same amount as the Pythagorean Comma. Theoretically, each 5th and 4th of the tuning chain is beatless. However, the inharmonicity of the coincident partials of all the 5ths and 4ths of the tuning chain must also be taken into consideration to determine the uniform beat rate of that chain in practice. In this scenario, the 2 : 1 Octave A3-A4 is wider than pure by flattening A3 by the same amount as the Pythagorean Comma (Beatless: 2nd partial of A3 = 1st partial of A4), the 5ths are pure, and the 4ths are pure on the 1st partial level.
If inharmonicity sharpens the 2nd partial of A3 by an amount that is more than the Pythagorean Comma, the reverse Pythagorean Comma emerges. Theoretically, the beat rate of each 5th and 4th of the tuning chain increases to compensate for the emergence of the reverse Pythagorean Comma. However, the inharmonicity of the coincident partials of all the 5ths and 4ths of the tuning chain must also be taken into consideration to determine the uniform beat rate of that chain in practice. In this scenario, the 2 : 1 Octave A3-A4 is wider than pure by flattening A3 by an amount that is more than the Pythagorean Comma (Beatless: 2nd partial of A3 = 1st partial of A4), 5ths are wider than pure, and 4ths are narrower than pure on the 1st partial level.
How is all of this relevant to the practice of tuning? The interplay between the inharmonicity of the coincident partials of the Octave A3-A4 and the inharmonicity of the coincident partials of each 5th and 4th of the tuning chain determines the uniform beat rate of that chain in practice. The aforementioned inharmoncities must be accounted for in each successive Octave from A0-A7 to extend Pure Octave Equal Beating Temperament beyond the Temperament Octave A3-A4.
Roshan Kakiya
Sent: 09-17-2025 08:53
Hi Peter,
I fed the terms "horizontal inharmonicity" and "vertical inharmonicity" into Perplexity AI.
"Horizontal inharmonicity and vertical inharmonicity are related to the concept of inharmonicity in music, which describes how the frequencies of overtones or partials deviate from exact whole number multiples of the fundamental frequency.
Vertical inharmonicity refers to the deviation of frequencies of the overtones (partials) within a single musical sound (or note) from the ideal harmonic series. This means the partials are not perfectly aligned as integer multiples of the fundamental frequency, causing the timbre to differ from an ideal harmonic sound. In string instruments, this inharmonicity happens due to the physical characteristics like thickness, tension, and elasticity of the string, which make the overtones slightly sharp or flat compared to exact harmonics.
Horizontal inharmonicity, on the other hand, occurs across different notes or tones in a musical instrument or musical context. This can mean the tuning or spectral relationship between notes is not perfectly harmonic or consistent. For example, in piano tuning, horizontal inharmonicity can describe how the tuning of different notes does not correspond exactly to ideal harmonic intervals due to physical inharmonicity of the strings and the resulting stretched tuning scale.
In summary:
Vertical inharmonicity: Inharmonicity among the partials within a single note.
Horizontal inharmonicity: Inharmonicity or deviation from harmonic relations among different notes across a musical scale or instrument tuning."
It has pretty much read my mind. Marvellous.
Roshan Kakiya
Sent: 09-16-2025 22:53
This according to Gemini AI bot:
"Horizontal inharmonicity" is a specific type of inharmonicity that occurs in a piano due to the two-dimensional vibration of the strings. While a struck piano string vibrates primarily up and down (vertically), it also vibrates a small amount from side to side (horizontally). This is because the hammer strike is not perfectly centered, and the bridge that transfers the string's vibration to the soundboard is much stiffer in the horizontal direction than the vertical.
Because the horizontal and vertical vibrations have slightly different frequencies and decay rates, they are not perfectly in sync. This phenomenon causes a subtle "beating" or wavering effect in the sound. While vertical inharmonicity-the more commonly discussed type, caused by the overall stiffness of the string-makes overtones slightly sharper than they should be, horizontal inharmonicity adds a unique timbral complexity and contributes to the characteristic "warmth" and rich, complex sound of a piano.
Roshan,
Is the above a reasonable facsimile of what you were saying?
Sent: 09-16-2025 10:16
Hi Peter,
Horizontal inharmonicity is the degree to which inharmonic partials deviate from their harmonic counterparts in practice, both of which are on the same partial level. There is no horizontal inharmonicity in theory because partials are whole multiples of the fundamental frequency. This has an impact on the position of the "needle in the haystack" that I have described below.
When one interval is tuned, multiple beat rates are present when its coincident partials are not in alignment. For example, to tune a beatless 3 : 2 5th, we have to align the 2nd partial of its upper note with the 3rd partial of its lower note to eliminate the difference between them in Hz. Only that coincident partial pair will be beatless when horizontal inharmonicity is present.
When two intervals are tuned, we are no longer listening to beat rates. Instead, we are listening to the quality of the intervals. I will use the 3 : 2 5th A3-E4 and 4 : 3 4th B3-E4 in EBVT to illustrate what is happening. The 3 : 2 5th A3-E4 and 4 : 3 4th B3-E4 share a common note, which is E4. When the 1st partial of E4 moves, its 2nd and 3rd partials move at the same time. Its 2nd and 3rd partials are non-coincident partials, and they are on different partial levels. Those partials are moving at different rates, which is vertical inharmonicity in theory and in practice.
There are two coincident partial pairs:
- 3rd partial of A3 and 2nd partial of E4 for the 3 : 2 5th A3-E4.
- 4th partial of B3 and 3rd partial of E4 for the 4 : 3 4th B3-E4.
The beat rate of the 3 : 2 5th A3-E4 and the beat rate of the 4 : 3 4th B3-E4 are moving at the same time when the non-coincident 2nd and 3rd partials of E4 are shifted at the same time. There will come a point where both beat rates are in alignment, i.e., the difference between them is 0 Hz. I am going a step further to ensure that the 1st partial of E4 has not split into two by making use of beat rate distribution ratios that are found in the harmonic series, i.e., the frequency ratio of E4 is 1 / 1. That is the specific "needle in the haystack" for the equally beating 3 : 2 5th A3-E4 and 4 : 3 4th B3-E4. The position of that needle is dependent upon the coincident partial pair of the 5th A3-E4 and the coincident partial pair of the 4th B3-E4 when horizontal inharmonicity is present.
I have only managed to find out that this is happening by expressing Bill Bremmer's aural piano tuning instructions for the EBVT mathematically. Something truly special is going on here, and I am still trying to make sense of it all.
Both of these examples show us how "purity" is achieved. Beatless intervals and equally beating intervals are connected because the overall objective is to have a 0 Hz difference between two Hz values.
What is your interpretation? I would love to know what others have to say about all of this, particularly on the application of theory in practice. If I have any holes in my understanding, please feel free to point them out and correct them. I have still got a lot to learn about the Equal Beating Temperament System.
Roshan Kakiya
Sent: 09-16-2025 07:35
RE: non-coincident partials
Someone correct me if I'm wrong here, but since non-coincident partials do not exhibit "audible" beats they are irrelevant to us tuners. The only "beats" we can manipulate toward our desired outcome are those we can detect. "Beats" only occur between frequencies that are relatively close together.
Again, if I'm in left field here let me know.
Sent: 09-14-2025 12:49
I'm currently using PiaTune, so in addition to choosing the midrange settings, there are multiple settings which transition to bass and treble. There is a 'magic wand' assist function that suggests, based on internal testing, which options may produce the better results for overall stretch. The chart that displays 3rd, 4th and 5th midrange beat rates for the chosen stretch has been very helpful, but limited as it applies to bass and treble choices.
Might not be helpful for your needs, but this type of app approach is fairly new, so I'm watching with interest for updates to come.
Ron Koval
Sent: 9/14/2025 12:27:00 PM
Hi Ron,
That is excellent news, but I still have a few questions. There are two types of inharmonicity.
There is the inharmonicity of coincident partials. For example, the 2 : 1 Octave. A beatless 2 : 1 Octave can be tuned by aligning the 2nd partial of the lower note with the 1st partial of the upper note.
There is also the inharmonicity of non-coincident partials. For example, the 3 : 2 5th A3-E4 and the 4 : 3 4th B3-E4. If I am trying to make them beat equally by sharpening the common note E4, I am shifting the 2nd and 3rd partials of E4 at the same time, which are non-coincident partials. The key is to make the beat rate of the 5th and the 4th align in such a way that the two 1st partials of E4 merge into one. I am sure that Bill Bremmer has explained how this process works much better than I can by stating that the aim is to listen to the quality of the intervals rather than the beat rates. In other words, the target is the production of 1 : 1 beat ratios rather than the counting of beat rates.
How is the inharmonicity of coincident partials being handled? How is the inharmonicity of non-coincident partials being handled?
How is the temperament being expanded beyond the Temperament Octave? Are you tuning Octaves, Double Octaves, Triple Octaves, and/or Quadruple Octaves?
Roshan Kakiya
Sent: 09-14-2025 11:13
Currently, the PiaTune beta for iOS is able to project beat rates of various intervals using the measured inharmonicty from the piano; useful for checking if the current settings and temperament strength is likely to accomplish the desired results. Send an email to support@piatune.com if you are interested in working with the beta version; he is very responsive to tech input.
PianoScope has just released an update that includes graphs similar to the ones on the rollingball website - and I believe the graphs will work with custom temperaments. The developer is working on another update that may include a "strength slider" to customize temperaments to achieve beat rates/equal beating as desired by temperament designers.
I stumbled on to this issue with Tim Foster's recent mild temperaments that were designed to have 3 pure, or nearly pure 5ths. (That brings up another topic - how pure/equal beating is close enough to achieve desired results?) When I checked the beat projections with inharmonictity and midrange stretch loaded, I found that a 50% temperament strength most often achieved those pure 5ths without making any others beat too fast for my liking.
PiaTune does go an extra step to apply corrections to partials of the inharmonictity constants which I believe allows for a more accurate representation of the piano scale which leads to a slightly different tuning calculation. The clue leading to this extra step was mis-matches observed in the display when stepping through different partials; if the inharmonicty data is accurate, it shouldn't matter which partial is selected for tuning since they all should agree. Instead of favoring the strongest partial, then the most stable partials can be favored for more stability in the visual display.
So yes, I believe the technology is there or nearly there to help accomplish your goal.
Ron Koval
Ron Koval
CHICAGO IL
