  • 1.  How to brighten a single note
    Posted 06-02-2026 20:11
    Greetings --
    Steinway D, 1983. New action parts and strings about 10 years ago. Over the last week or so the D5, first note above the treble action break, started sounding muffled. The rest of the piano sounds fine. I found that spacing was a little too far to the left relative to the D#5 above it, and the right string had made the hammer shape a bit lopsided as a result. I recentered the hammer, filed it down a bit so it was once again flat and square with the strings, and this helped a lot. But it still sounds slightly muffled in relation to the notes on either side. Touched up voicing of the surrounding notes and got another good improvement, but it still needs a tiny bit more. Today's question: How can I brighten up that one note, D5, just a little bit, so that it once again fits in but doesn't over power it's neighbors?
    -- Thanks
  • 2.  RE: How to brighten a single note
    Posted 06-02-2026 21:48
    Geoff
    One trick I do to brighten up a note just a little is to take the voicing tool, turn it upside down, and use the blunt end of it to smack down on the hammer. Support the hammer with your voicing block and give it two or three sharp blows. Repeat, if necessary. If that doesn't do the trick, add a few drops of B72.
  • 3.  RE: How to brighten a single note
    Posted 06-02-2026 22:17
    Wim --
    Smacking it! Yes! You don't use a trick for quite a while and you forget it. Thanks for the reminder.
    I'll see if I can find some B72 as well. Thanks.
  • 4.  RE: How to brighten a single note
    Posted 06-02-2026 22:25
    Wait.  With the action in the piano, press lightly with the blunt end of a mute on the unison strings (to absorb the blow) and play the note vigorously a few times to compress the hammer surface. Test for the sound, repeat a few times if needed. This can be done in 30 seconds.
  • 5.  RE: How to brighten a single note
    Posted 06-03-2026 01:21
    Here is a question and response:
    How dilute could you make B 72 for a hardening/brightening solution and it still would be effective?  I have had good results with a 1% solution (one gram in 100 grams of solvent) and at that level I don't risk excess hardening.
  • 6.  RE: How to brighten a single note
    Posted 06-03-2026 08:52
    If let-off was low on that one note compared to its neighbors, it could contribute to the perception of it being a bit muffled.
    www.PianoCraftTechnicalSchool.com
  • 7.  RE: How to brighten a single note
    Posted 06-03-2026 09:20
    Pardon me for stating what may be obvious to many, but I would not do anything to alter the state of the hammer felt until all regulation parameters have been confirmed as correct and consistent, including hammer/string mating.
