  • 1.  Kawai KG-2 Damper tray Pitman grommet
    Posted 12-30-2025 11:48
    In reconditioning the damper system on this 1981 KG-2, I was trying to pull out the rubber "grommet" from the aluminum damper tray and it tore in two. It's kind of a T shaped thing that none of my rubber thingys resembles.
    Has anyone else encountered this situation and contrived a suitable solution to replace this reasonably easily?  I'm trying to devise something as I write this but hoping someone has done it already.
    I have not yet called Kawai to see if a 1:1 replacement is readily available.  I kind of need it now 😉
  • 2.  RE: Kawai KG-2 Damper tray Pitman grommet
    Posted 12-30-2025 13:42
    You can get it working with heat shrink tubing and a balance rail felt punching.
    Shrink the appropriately sized tubing onto the pitman pin - maybe even 2 layers would be a good idea.  Then put the balance rail punching on, and apply some Protek grease.
    But also, Kawai parts is likely open today.  It will be expensive to get something overnighted, but they might be able to do it. 800-421-2177
    Don Mannino
  • 3.  RE: Kawai KG-2 Damper tray Pitman grommet
    Posted 12-30-2025 17:42
    Thanks Don,
    Thats a good emergency plan. As it turns out, I found a grommet in my drawer that actually fit the hole for now. I spoke with Jeanie on the phone and have a couple of "authentics" coming.
