Sent: 3/12/2023 7:12:00 PM
Subject: RE: key frame glides
OTOH, unless it's a problem (a real problem) it's not worth all that effort. Plane the front and rear rails till the balance rail rests solidly on the keybed.
Sent: 03-12-2023 13:44
Subject: key frame glides
Drilling through the keybed could really rip it up using spade bits or cheap Forstner bits. On top of that most Forstner bits are made for use in drill presses.
There is a drill guide that allows a drill to become a mini drill press. To use it to make holes for inserts you would need to use it from under the piano. A pilot hole should be drilled from inside the action cavity with a right angle drill chuck . To get a clean cut you need to invest in a high quality Forstner bit. I recently bought a $50 metric Forstner bit from Infinity Tools . To prevent tear out of the hole inside the action cavity mount a sacrifical piece of wood inside the action cavity using sheetrock/drywall screws. This way when the forstner exits it will not tear out the exit hole.
Drill a little at a time removing the bit cleaning out the sawdust and inserting the bit in the hole. this will prevent burning and damaging the bit
This drill guide4 and technique is also good when enlarging the opening for the Pitman on Steinway & Sons grand
Sent: 03-12-2023 12:28
All of this is why (when I was faced with the same dilemma) I opted to create Teflon pads of the appropriate thickness as ersatz BR glides. Worked quite well, and I'd do it again under similar circumstances.
Sent: 03-12-2023 11:35
I seem to remember some discussion about this a long time ago. Drill a hole the size of the shank of a spade bit where you want the insert. You'll have to do a bit of grinding and filing on a your bit to create cutting edges on the back side where the shank and blade meet. Insert the bit from the top of the hole, then insert the bit into your drill from below the keybed. You can cut your hole from there. No, I haven't done this myself, but it would work. Of course, you'd have to have clearance from the lyre plate, trapwork levers, etc.
Sent: 03-12-2023 11:05
Hi everyone,
I had posted a similar query about a glide-less Bluthner, and it got me wondering: if one is going to install hardwood inserts into a keybed, how would you drill the holes? I would think a Forstner bit, but what do you do if there's no working room in the action cavity? I've looked at Forstner bits-you'd have to get a 1/4" hex shank for use with a 90° drill adapter. But you can get only the smallest sizes with a 1/4" shank. I use a 1" spade end bit for countersinking t-nuts for new lyre bolts, but I assume that doesn't make a suitable hole for an insert.
Scott Cole, RPT
rvpianotuner.com
Talent, OR
(541-601-9033
Sent: 03-11-2023 22:28
A piano this age has a lot of wear on it and the parts may be at the end of their useful life. While a solid keyframe contact with the keybed lays the foundation for regulation you need to assess all of the parts, hammer wear, knuckle condition, whippen (wippen, balancier, repetition) condition, spring strength, punchings, key height, hammer flange friction, backchecks.. Try to get the end notes in each section paying attention to jack position, jack travel in the window.
If the knuckles are out of round bolster them. If knuckles are flat, worn down fuhgetabouit... replace the knuckles. How high are the drop screws ? do they scrape the pinblock ? Remove a wippen and check the friction on the flange, jack,rep lever as well as all of the felts and operation of the rep springs. Do the springs have cords, adjustment screws or are they butterfly type-if so clean the grub
Sent: 03-11-2023 21:11
Mark.
As Larry pointed out, bad regulation is not because of a lack of glide bolts. There are other problems that need to be looked at. Key dip, hammer blow, let off, drop, etc. What about friction in flanges?
One place many technicians overlook is the position of the jack in relation to the knuckle. That makes a huge difference in let off.
WIm
Sent: 3/11/2023 8:31:00 PM
I'm confused. Key frame glides are to reduce friction and bed the balance rail. If you don't have enough dip, add punchings at the balance rail pins. Maybe the key dip is correct and your hammer blow is wrong.
Sent: 03-11-2023 18:24
It may have been designed that way that dosent mean its right ( I work for a Steinway dealer enough said:) Its 105 yrs old and won't regulate correctly at this point so with the glides it should work just fine
and yes I have dried the holes slightly smaller the threads don't seem to be : self threading into the oak frame
