Thank you to all. I had not thought about, or realized, how easy it is to work directly with the lead rather than needing to use glue. Regards, Norman.
potomacpiano@verizon.nethttps://potomacpiano.com(301) 983.9321
Sent: 08-01-2023 13:35
Subject: Loose Key Weights
Grizzly has a 1 ton arbor press with interchangeable dies that are held in place magnetically. Harbor Freight has a small cast iron anvil which when
combined with PianoTech punches is usefull for shop or road. Dental tools are usefull for tightening loose key or underlever leads.
Parker Leigh
Sent: 08-01-2023 12:43
Hi all,
At a convention class last week, David Hughes showed the use of an arbor press to install/remove key leads. Harbor Freight has one for about $69, but there others available. He modified a machine screw of appropriate size by cutting some teeth with a hacksaw, which is what does the swaging. He also noted to me that removing leads that have been glued in can be problematic.
great to see you at convention!
Scott Cole, RPT
rvpianotuner.com
Talent, OR
(541-601-9033
