I will be drilling a pinblock, shortly, for a piano that is not set up for tuning pin bushings. This will be my first time drilling in this configuration.
I am considering how best to mark the block in preparation for drilling. I want to avoid having any of the pins rubbing against the plate, at least for the first several decades.
I have a set of transfer punches, so I have a choice of diameters.My first thought was to choose the largest punch that would fit in the plate holes (bass and low tenor holes are .325" and the rest are .375") and to angle the punch so that it leans away from the keyboard end of the plate, in other words, the opposite direction to which the tuning pins will lean. This morning it occurred to me that it might make sense to choose a slightly smaller punch, same lean, and thus place the marks a little closer to the keyboard edge of the block, My idea is to position the hole so as to slightly compensate for the tilting force that the string will exert on the pin.
Thoughts and advice?
