Dealing with one of the longest tenor breaks of any piano, I started with having to make 4 over dampers. But through much tweeking I was able to eliminate 3 of them and was left with one, which was from a node problem. To make the over damper is easy- bend music wire to shape with a loop at the top to sandwich the back of the damper head with another piece of felt.
"Where Tone is Key"
Piano Designer and Maker
Designer of Inertia Touch Wave
Sent: 04-30-2023 21:22
Subject: modulating upright piano damper after-ring
Aren't the dampers on those models the long ones with 3 felt blocks? If your surmise is correct that the problem involves touching a node, perhaps the middle or bottom block could be trimmed or removed to avoid the node if you can locate it. Or perhaps replacing a block with a less dense treble felt block.
I understand your desire to solve this in one trip but this kind of problem can be vexing. The wire extenders aren't a guarantee either. I had a similar problem with dampers last summer, it wasn't a profitable venture for me. >:P
Sent: 04-30-2023 16:40
Not sure the model but 52" probably 10 years old
Sent: 04-30-2023 11:06
May I ask what Model this is on?
Zackery Hardy
Elk Grove CA
(916) 531-5150
Sent: 04-29-2023 01:50
I work on a MH upright, newish, that has an annoying after-ring that clearly emanates from the monochords only. I'm looking for solutions that folks have found to this issue by installing damper extensions. There's plenty of force on the strings applied by the damper springs, in fact, more than is desirable in terms of touch characteristics, so it's not that and I'd prefer not to increase that force even if it were to have the desired effect.
It may be that the dampers are touching or are near a harmonic node but there aren't any realistic options to moving the dampers. So the only options seem to be extending the existing dampers by installing longer dampers or adding a damper wire extension (see below). What have any of you found to be the most effective and if it's the wire extenders where did you get those parts and how did you go about attaching them. I'm thinking this type of idea though for the monochords (the picture below is for the low tenor),
