Hi Ed, I also have seen this on a stepped block and would tend to agree that if the block fits well along its length, especially if that is along the top near the webbing, things should good enough. While this may be by design, I would ask if it is simply a cost cutting measure.
I recently created a new block for a vintage Weber ( also mortised into the sides ) , this block had 3 steps including a bass cap. Thank you Christian Bolduc for your instruction on fitting a mortised block.
Sent: 3/3/2025 7:31:00 AM
Subject: RE: Odd Tuning Stability
Unless I missed it, no one mentioned the plate webbing screws holding the pinblock in place.
Sent: 03-02-2025 15:36
Subject: Odd Tuning Stability
Some years ago I had reason to pull the plate of a Kawai RX-2, checking for water damage.
There was an intentional gap along the front, vertical faces of the plate and block.
At the top inner corner of the plate there was a carefully shaped extra step which fitted neatly into a notch along the corner of the block.
The fit was exquisite. But if someone did the business card diagnostic they would have concluded that the entire front edge of the plate/block fit was gapped.
Sent: 03-02-2025 13:07
I have heard this reasoning of tuning pin bushings acting as a fulcrum and pulling the pinblock toward the stretcher thus negating the need for a good flange fit. This does not sound like a stable system to me.
The block should fit top, bottom, left, right, front and rear from my experience.
Sent: 3/2/2025 12:54:00 PM
You will most likely find a gap between the pinblock and the plate flange. Not doing that fitting is often by design. More than one piano maker seems to rely on two hundred and thirty some-odd tuning pin plate bushings to perform the same function as fitting the block to the flange. Not than shimming or epoxying the gap won't help. It should.
Let us know what works in this case!
Sent: 03-02-2025 12:47
I would recommend checking the flange fit with a .001 feeler guage as well. You would be surprised at how many pianos are poorly fit - both new, old and rebuilt.
