Tough situation. All of our hammers are custom bored and hung in the shop now but many years ago, when using pre-bored hammers, the boring was sometimes a little larger than desired. The quick fix that I learned as an intern was to stick the shank in my mouth, wet the end of the shank, remove excess liquid and hang the hammer. I don't know of any failures from that. Of course, it's all a matter of degree of the difference in shank diameter and size of bore but this generally worked.
Sent: 10-15-2025 00:26
Subject: overly reduced shank fix?
How reduced is it? I would say that going even from 3/16 to a 7/32 is not something I would want to do. But if you were determined to do it, I would just probably do what Chris suggested and use the Titebond trim glue, which is very thick, and hope you don't leave any gaps in there. The concern I have is shrinkage over time and those hammerheads coming loose. Might not happen, but it could. I suppose you could plug all the holes with dowels and re bore. It's a little tricky with hammers that are already tapered, but you can do it.
Sent: 10-14-2025 23:36
Thanks for the answers all, but what I was really looking for was how to fix a (possibly) overly reduced shank. I can deal with the customer.
Any answers to my original question?
-- Scott Cole, RPT
Editor, PTG Journal
Serving Southern Oregon and Northern California
(541)601-9033
Sent: 10/14/2025 10:29:00 PM
Subject: RE: overly reduced shank fix?
I agree with David L. The rehung old hammers will almost certainly not go back on the way they were originally, it's much more difficult to hang ill fitting hammers. At minimum, you will have to file and shape them; so they probably won't sound like they did before in the piano. Then what? I wouldn't want to take responsibility for that, it's too problematic. Does the customer think it's like changing tires on a car?
With two hung hammer sets at least you can easily do side by side comparisons. This customer is costing you a lot of time just fielding their issues. Make it clear to them that they have to pay you to indulge them.
Btw, this would have been a disaster for me as I cut the old hammers off when I'm replacing them.
Sent: 10-14-2025 21:40
If he requested the hammers be rehung and chose the hammer and refused your suggestions about samples then I would tell him you can rehang the old hammers but it will require a new shank for reasons mentioned and I would charge for the parts and labor. You can leave him the new set, shanks attached, in case he changes his mind again.
Customers who side step your expertise and make their own choices are responsible for the outcome. This is not your problem, but you can help him resolve it at his expense. I would also tell him that before he spends the money on putting it back as it was it makes more economic sense (for him) to try to voice it. What does he expect you to do with the new set?
I run into this periodically, a customer who claims to know everything and knows nothing but what they read in some chat room. I usually walk away
What kind of piano, btw, and what hammer did he insist on?.
