When you have a white finish, getting a perfect match is next to impossible. Because this is on the edge, you might get away with just getting it close. I don't know about the new UV curing resins. I saw the system at Reno, and purchased the kit but haven't tried it out. If it was me, I'd take a cheek block to an automotive paint store to have a custom match made in a spray can. Bondo, or polyester sanding coat and primer to fill in the gouges, then topcoat with your custom lacquer or enamel spray. Optional clear coat.
If this was on the top panel or anywhere there is damage on a large open surface, I'd recommend doing the whole panel rather than spot it in.
