  • 1.  repinning after CA?
    Posted 03-01-2023 11:24
    Can a block be re-pinned after CA has been used, or does this present "issues"?  I've only been using CA applications for the past few years, and having encountered one application that had failed (after sometime), I'm wondering what options are available "post-CA" other than a new block?
    Timothy Edwards
    Beckley WV
    (740) 517-7636
  • 2.  RE: repinning after CA?
    Posted 03-01-2023 11:31
    If pins are still loose after CA, it's most likely cracked. Adding more CA is not going to do the trick. Nor will repinning. The best option at this point is a new block.
